Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 57
Thread: GMLAN SW-CAN Message woes
  1. #41
    Aug 2011
    Joining in on this conversation. Brad has been very helpful! I think I'm starting to get some relevant data, but its still tricky to decode. I need to keep studying the 29 bit header part so i understand whats happening.
    My main issue at the moment is that I cannot get the doors to lock/unlock. I don't think i have the same can id as some of the other GM cars. mine is a 2011 Camaro.
    Interestingly, besides canID 40, these are the only ids that show up for me:
    99
    60
    80
    58
    62
    8e
    59
    bb
    a9
    67
    97 (onstar)
    They are the 4th set i believe of this packet:
    10 81 40 99 00 00
    10 8E 00 80 0B 0A 05 02 00 35
    10 AE C0 BB 0F FF FF FF FF 80 00 30
    do any of those can ids ring a bell?
  2. #42
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by Jakob Perry View Post
    99
    60
    80
    58
    62
    8e
    59
    bb
    a9
    67
    97 (onstar)
    10 81 40 99 00 00
    my door locks are a single message. To figure it out, I hit the keyfob lock key 4 or 5 times and log the results. Find codes that only show up 4 or 5 times and then push those back on the bus. If one of them works, victory!
    Former author of LinuxICE, nghost.
    Current author of nobdy.
  3. #43
    Jul 2005
    Michigan
    99
    60
    80
    58
    62
    8e
    59
    bb
    a9
    67
    97 (onstar)
    10 81 40 99 00 00
    So you have the right idea, unfortunately this vehicle is a bit unique. This is because the Body Control Module is responsable for unlocking the doors AND receiving the RKE key fob commands so there is no reason for there to be a CAN BUS message to control the locks on this using the RKE messages. So don't bother with pressing the key fob and trying to find a command to replicate, this won't work.
    HOWEVER, OnStar has a message it sends to control the locks. So you can simply watch for that message:
    Unlock Drivers Door is: 0x1024E097 00 02 FF
    Unlock All Doors is: 0x1024E097 00 03 FF
    Lock All Doors is: 0x1024E097 00 01 FF
    If you are going to do an Unlock or Lock from a Sleeping bus you will need to send a High Voltage Wakeup and a VNMF Frame (0x641 01 FF FF FF FF FF FF FF will work)
    And if you need to turn on your heated seats try this sequence:
    0x102A0099 04 (Send multiple times to simulate multiple heated seat button hits)
    delay 100 ms
    0x102A0099 00 (Send this to simulate release of the button)
    Want to remote start your car (works only if you have a factory remote start installed and enabled), send this sequence:
    0x1024E097 80 01 FF
    delay 200ms
    0x1024E097 00 00 FF
    and Cancel Remote start with:
    0x1024E097 40 00 FF
    delay 200ms
    0x1024E097 00 00 FF
    Hack your car's CAN BUS at www.canbushack.com
  4. #44
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Is that heated driver or passenger seat (or both)?
    Quote Originally Posted by chewwtoy View Post
    delay 100 ms
    0x1024E097 80 01 FF
    delay 200ms
    0x1024E097 00 00 FF
    0x1024E097 40 00 FF
    delay 200ms
    0x1024E097 00 00 FF
  5. #45
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    I can't manage to get the bus to wake up. I do this:
    1) high voltage on (athv1)
    2) switch to 11bit mode
    3) send the network wake up (621 01 FF FF FF FF 00 00 00)
    4) switch back to 29bit mode
    5) send remote start (080080B0 01 0B)
    6) high voltage off (athv0)
    The same sequence works when I manually wake up the network by pressing a button on my actual fob. Do I have something messed up in my sequence? For the record, I also tried 0x641 01 FF FF FF FF FF FF FF.
    Also, my door unlock command seems to be trying to lock the doors: (080080B0 03 01).
    EDIT: door unlock didn't work because I had the data backwards. Should be (080080B0 01 03).
  6. #46
    Jul 2005
    Michigan
    Quote Originally Posted by tripzero View Post
    I don't really know ELM too well, so I will just say, that the AT HV1 needs to be followed by a message with the ID of 0x100. then AT HV0. The whole thing doesn't need to be High Voltage just one message at the beggining...
  7. #47
    Jul 2005
    Michigan
    Just the Driver.
  8. #48
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    So in other words:
    -->2a) send message with id 0x100: (100 FF FF FF FF FF... something like that)
    -->2b) athv0
    Awesome, I'll give it a try. Thanks.
  9. #49
    Jul 2005
    Michigan
    Also make sure you have at least 100ms of space between some the messages... This will ensure that the module is ready to receive input.
    Plus the 0x100 message do not need any data. (You can add it if you like, but it's not needed)
  10. #50
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    What's the standard procedure for knowing when things go to sleep? Right now I'm sending a wakeup and initializing the virtual network every time I send a command. This seems inefficient.
    Also, strangely since I added the 0x100 message, my remote start command doesn't seem to be working correctly. I see the lights go on/off like it normally does when it remote starts but the engine never turns. Keyfob still works. All my other commands seem to work still as well. I will keep toying...
  1. Hello - Trouble with CAN message IDs
    By Altazi in forum Newbie
    Last Post: 08-14-2008, 03:26 AM
  2. "Low signal from GPS" message criteria
    By parksgm in forum StreetDeck
    Last Post: 10-23-2007, 05:11 AM
  3. Replies: 2
    Last Post: 06-13-2006, 10:22 PM
  4. What do you think of my playlist??
    By SkinnyBoy in forum Software & Software Development
    Last Post: 07-19-2001, 12:51 PM
