Results 1 to 10 of 15
Thread: What diagnostics cable & software for BMW 2.5 TD 1995
    Newbie tsam19's Avatar
    Jun 2010
    Question What diagnostics cable & software for BMW 2.5 TD 1995
    Hello all
    I'm looking to buy a diagnostic device to plug into the 20 pin socket under the bonnet.
    There is no OBD1 / 2 socket in the car as it it PRE 1996.
    However I can buy an adapter - 16 pin OBD2 to 20 pin BMW.
    1) Which would allow me to connect the OBD2 end to a OBD2 handheld device.
    2) Alternatively I could connect the OBD2 cable end to a VAG com type cable with the USB on it, so I could plug the usb into a laptop & the 20 pin end into the BMW.
    VAG CABLE
    http://cgi.ebay.co.uk/409-1-KKL-VAG-...item4ceffec6f7
    BMW CABLE
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
    Or buy a kit as follows:
    BMW KIT
    I know the VAG com cable is for the volks/audi/seat groups, but if i linked it to the 20 pin bmw cable & had the right software I'm sure it would work.
    I presume its the diagnostic SOFTWARE on the disc that gets the cable working etc.
    I look forward to any replies.
    Oct 2008
    There's no 16-pin socket because the car is pre-2004.
    Diesels in Europe only had to comply to EOBD starting at 1st. January 2004.
    You'll need something like Carsoft for this one.
    Jun 2010
    I already know there's no 16 pin plug in the car as my opening thread post states.
    Please read the post properly.
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    Unfortunately the ONLY thing that will work with 100% sertanty on your car is a CarSoft 6.5 (or newer) kit. This is the same tool BMW mechanincs use.
    For a long time CarSoft only used serial connection, and where quite pickey on the USB->Serial adapters.
    Carsoft: Home Edition
    http://www.carsoftinternational.com/...oft_bmwv73.htm
    Oct 2008
    Have you read my post? Especially the last word of the 1st sentence?
    Have you read the 3rd line? I know that's not what you want to hear, but that's how it is.
    You have had a similar answer on another forum. Now you can ask the question on 10 more forums, the answer is still the same.
    You need BMW-specific software. There's no cheap solution.
    Mar 2009
    ^^ As I said earlier... The only thing that will work for reading fault codes and resetting them is original software and equipment.
    Though. I do know of people that have been able to use "taiwan special" hardware, but the still needed to use CarSoft's software.
    May 2009
    Did somebody try revers protocol(s) on BMW ?
    Why there is no cheaper solution ? Is there some type of crypting ?
    Tomas
    Jun 2010
    What about BMW & MINI DIS (v57) SSS (v32) and BMW TIS (v8) someone suggested this would work or cover the car I want to use it on.
    I have heard of people buying the VAG cable (see pic in 1st post) then connecting it to the BMW cable (see pic 1st post) - so you have a USB connector one end & 20 pin socket the other.
    You connect the VAG OBDII cable male end to the BMW adaptor OBDII female socket.
    Basically you link the 2 cables together.
    Then via the above software DIS v57 or the carsoft 6.5 software you can access the car.
    Oct 2008
    Yes, I reversed engineered the BMW protocols for several manufacturers of aftermarket scanners. But that is an entirely different price class - a lot more expensive than Carsoft.
    You can buy Carsoft for a few hunderd euro. Professional aftermarket scanners are several thousand.
    Oct 2005
    UK
    Easiest and most cost-effective route is the FCX3 (http://www.ukobd.co.uk/shop/12-bmw-t...rch-fcx-3.html) which plugs straight into the port.
  1. Got ford software but which cable do I need...
    By b_kennedy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-17-2009, 02:06 PM
  2. Elmscan 5 w/bluetooth wireless obd scanner reviews
    By speedy007 in forum The Review Palace
    Last Post: 06-02-2008, 06:59 PM
  3. OBD2 Audi A3 Cable Software
    By hacky1224 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-03-2006, 09:41 AM
  4. Tactrix Cable Problems with all software
    By fire in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-14-2006, 11:21 PM
  5. OBD 1 Diagnostics software?
    By MaleBuffy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-13-2005, 08:05 PM
