Results 1 to 6 of 6
Thread: OBD-II Mode Questions?
    Aug 2010
    Question OBD-II Mode Questions?
    Hi,
    I am trying to talk to my car using an ELM327 with some terminal software.
    I can get the basic AT commands to work.
    However what I can't work out is how to put the unit into OBD mode so I can start
    taking readings from the car.
    Can anybody give some pointers or a simple example so I can follow.
    Thanks,
    Ward
    Oct 2008
    What car is it? Make, model, model year, engine (petrol, diesel).
    In which part of the world do you live? Usa, Europe, Japan?
    May 2010
    Thanks Guys I have same problem .. I don't know how to start .. I'm looking for something like that ..
    I have Mercedes Benz 2006 (E200 Komposser petrol) and I'm in (Europe-Germany).
    Best Regards.
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    These units don't have different modes of operation as you describe. Plug it in, you're good to go.
    If you've seen stuff by using AT commands, the next thing to try is "0100". Mode 1, PID 0, is your baseline "car, tell me what you can do". If you see numbers, good. If not... less good.
    I suggest reading the elm327 datasheet from elmelectronics.com. Three fourths of what I know about using OBDII was gleaned from that.
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
    Aug 2010
    Hi,
    Thanks for the responses - the car I have is a:
    "Australian" Holden 2003 VY Calais V6
    I tried the codes as suggested 0100, however I kept getting the error
    BUS INIT: ...ERROR
    So what I am doing wrong. What protocol does this model support?
    Thanks,
    Ward
    Oct 2008
    I think Australian cars have to comply from 2005 on?
    Car is probably not compliant with anything.
    You would need a Tech-2 to communicate to it.
  1. General help needed with OBD II protocols
    By kevin1162 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-06-2010, 04:38 PM
  2. Wiring in OBD II Scantool
    By HisSketchiness in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-20-2008, 01:27 PM
  3. OBD II for Landcruiser diesel?
    By Joehule in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-03-2008, 05:26 AM
  4. Replies: 0
    Last Post: 11-03-2007, 04:33 PM
  5. Where went the Guages in the OBD II plugin?
    By bns2000 in forum Centrafuse
    Last Post: 08-11-2006, 11:39 PM
