Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: elm 327 interface with laptop problem
  1. #11
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Quote Originally Posted by p2psmurf View Post
    With 55-plate you mean model year 2005? That should be compliant, even when it's a diesel. I suspect your interface is the problem. Check it on other known compliant cars.
    Petrol passenger cars 2001 and up. Diesel passenger cars 2004 and up.
    Do you know whether the EOBD legislation applies to hybrids and electrics?
    There are different variations of the Citroen C4, though I'm sure if it wasn't gas or diesel powered the OP would have mentioned it.
    Vitaliy
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
  2. #12
    Oct 2008
    Yes. Hybrids should also comply. Have to check for the first year, but it's no later than 2003 for a petrol/electric. A petrol/electric hybrid I think falls under petrol - so I think 2001. A diesel/electric falls under diesel - so I think 2004. That's for passenger cars. Normal rules for commercial vehicles also apply. Exception for hybrids is that with the MOT-tests you do not have to measure CO. Obviously because the petrol engine would not fire up.
    Only exception would be a vehicle with natural gas as main fuel. That may have an extension up to 2006.
  3. #13
    Oct 2008
    Vehicles with NG or LPG became compliant between 2003 and 2007.
    See: http://eur-lex.europa.eu/LexUriServ/...1L0001:EN:HTML
    The rules for Petrol and Diesel:
    See: http://eur-lex.europa.eu/LexUriServ/...9L0102:EN:HTML
    If you want you can also download these documents as PDF file.
  4. #14
    Dec 2006
    Phoenix, AZ
    Thanks! I remember seeing these documents several years ago, but I don't think they had provisions for anything other than petrol and diesel.
    Do you know where they define "vehicles of category M1"?
    Vitaliy
  5. #15
    Oct 2008
    Exact definition is somewhere hidden in the EU documents, not related to EOBD I am afraid.
    As far as I know: M1 are passenger cars.
    N1 are commercial vans (Think Mercedes Sprinter but also Peugeot Expert or VW Caddy).
    Class I = empty weight < 1205kg, Class II = empty weight 1205 – 1660kg, Class III = empty weight > 1660kg
    The documents are changes to the original documents from the seventies.
    The NG and LPG exemptions are defined in 2001. Since then there have been numerous other changes.
    The big problem is that you can't download the document as it is today.
    You have to download the original 40 year old document and 40 years of changes (or changes to the changes).
    Hope you have a sufficient supply of aspirins.
  6. #16
    Dec 2006
    Phoenix, AZ
    Class I = empty weight < 1205kg, Class II = empty weight 1205 1660kg, Class III = empty weight > 1660kg
    American headache is treated with Tylenol.
    Thanks a bunch for the info!
    Vitaliy
  1. elm 327 won't talk to PCM..........or maybe it's the other way around.......
    By greatwhite in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-12-2008, 10:33 AM
  2. BUS/Unilink Adapter for Sony HeadUnits (a laptop interface)
    By Anarchi in forum General Hardware Discussion
    Last Post: 07-25-2005, 06:25 AM
  3. Laptop and low sound volume problem
    By Hark in forum Car Audio
    Last Post: 07-13-2005, 05:49 PM
