Results 1 to 7 of 7
Thread: CAN BUS how to get data
    Sep 2010
    I have OBDKey. It allows to get data from OBD2/CAN BUS. I've received data using OBD2 (standard PIDs), but I have problems with CAN messages.
    Should I sent some AT commands to work with CAN? What are they?
    How should I send message_id to get data from it? What is the format of sending data?
    Low Bitrate sinclairvital's Avatar
    Jun 2005
    The commands ATCM0000 and ATCFFFE0 will set the CAN filter and mask to accept ALL incoming frames.
    This is so you can see all the frames on the bus. If there is nothing there, you will just get “waiting …” from ATMA.
    Using a Ford ECU, I get this trace (to quit ATMA send any key):
    atz
    OBDKey 1.30
    atsp6 (to set to CAN 11 500)
    OK
    atcfffe0
    OK
    atcm0000
    OK
    ath1
    OK
    atl1
    OK
    atma
    Waiting...
    0420FFFF00FF6A00FF00
    0200000000000000803F
    0420FFFF00FF6A00FF
    OK
    There are other methods too for advanced filtering and variable lengths.
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Hm, the log doesn't look exactly like what you would expect from an ELM327. Do you disable spaces by default?
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    Sep 2010
    CANIDs Ford Fusion and FORD Fiesta
    Are the different CANIDs for the same parametr(for example EngSpeed) using in Ford Fusion and Ford Fiesta? Or they are the same?
    Sep 2008
    depends on the parameter. For OBDII defined parameters, like speed, the data will be at the same CANID, Mode and PID.
    May 2008
    I'm also very interested in getting data off of the CAN BUS (specifically HS-CAN) from a Ford vehicle... but I'm working with a F350 truck with diesel engine (2008, 6.4L).
    Has anyone found a source for the frame identifiers (IDs) used on the HS-CAN?
    Dec 2006
    Phoenix, AZ
    jantman,
    If you just want to see what CANIDs are present on the bus, monitor with ATMA (all filters off).
    Vitaliy
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. Developers Discussion
    By Borte in forum OpenMobile
    Last Post: 10-11-2009, 07:04 PM
  3. Tapping into CAN bus
    By ptk in forum General Hardware Discussion
    Last Post: 10-28-2005, 09:11 AM
  4. Laptop 10.4 pinout
    By Blazenhazn in forum LCD/Display
    Last Post: 10-10-2005, 07:04 AM
