Results 1 to 5 of 5
Thread: Need Help - Features Of My Car's OBD
    May 2008
    Nassau, Bahamas
    Exclamation Need Help - Features Of My Car's OBD
    I am trying to figure out what features i can use OBD II in my neon, will i be able to get all features Centrafuse or Scantool uses such as
    Intake Air Temperature
    Engine Load
    Fuel Pressure
    Air Flow Rate
    Intake Manifold Pressure
    Etc?
    A few of these showed as N/A what does that mean?
    May 2008
    Nassau, Bahamas
    On/Off Switch For OBD II
    Next question i did some modifications and was wondering if there is a way to turn the OBD II hardware off and on with out unplugging because of the wire length. The device will be hidden under my Center Console...Good or Bad Idea?
    Oct 2008
    N/A means Not Available.
    The only way you can switch off the hardware without unplugging is adding a switch to the 12 volt feed on pin 16.
    May 2008
    Nassau, Bahamas
    Ok should i add that switch on the car side or the OBD wire hardware side?
    Oct 2008
    Whatever is easier to fit I think.
  1. microOBD 200: complete OBD interface in DIP-24
    By Vitaliy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 09-16-2010, 12:37 PM
  2. Rev App for iPhone. Wireless OBD 2 app
    By optikalefx in forum The Review Palace
    Last Post: 01-29-2010, 12:40 AM
  3. The mobile Internet makes its way into cars
    By DarquePervert in forum Wireless Communications
    Last Post: 08-24-2009, 11:11 AM
  4. Hardwired OBD scanner and motor vehicle inspections
    By 01black_ac in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-29-2006, 11:40 PM
