Results 1 to 6 of 6
Thread: What is the response 7f 22 13?
    Sep 2010
    I want to get data using OBD2 Pids
    Send 22210
    Received 7f 22 13
    I know that 7f is negative response But what does 22 and 13 mean? Could you help me?
    Newbie Saran_yim's Avatar
    Oct 2010
    Thailand
    Negative response for command 22 13
    did you send command like 22 13 xx before?
    Oct 2008
    7F Negative acknowledge (NAK)
    22 The command send to which this NAK applies
    13 The reason why the command has been denied. Not defined in SAE or ISO so manufacturer specific.
    Sep 2010
    I sent command 22 210. So 210 is CAN message id for Ford. What is it wrong? How should I send this message id?
    Sep 2008
    Quote Originally Posted by vnovikov View Post
    If that is the case, you need to put the message ID first then 22 is your mode and you will need to supply a PID.
    Mar 2008
    Arizona
    A mode $22 request requires two bytes. 22 210 would have to be either 22 0210 or 22 2100. I am not aware of any Ford PIDs with those IDs, though. If you want to monitor a CAN message with ID of 210 then you would have to do a MA after setting the CAN mask and filter. ATCM FFF and then ATCF 210 followed by ATMA. You will get DATA ERROR messages if the third byte is zero unless you turn off CAN formatting.
  1. OBD-II Not working for scantool.net ISO
    By andy@ukcars in forum CF Bug Reports
    Last Post: 08-07-2008, 10:57 AM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. Replies: 8
    Last Post: 07-16-2006, 02:02 PM
  4. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
  5. Anyone understand Java ? I need help.
    By frodobaggins in forum Software & Software Development
    Last Post: 05-24-2004, 11:53 PM
