I don't think you are being specific enough for an answer. What did you have in mind to do?
For example, nearly any of the OBDII
software will read and clear trouble codes. Name brand
connectors and cables like OBDLink work with little difficulty while Chinese knockoffs sometimes do an sometimes don't.
You can build gauges and panels using
DashCommand software and you can eliminate wires if you use a
WiFi OBDII connector.
RR has OBDII plugins and so does CF. OM, I don't know, but probably or if it doesn't, it will soon.
Some of the software is free, some is not. Some of the pay for use software has the additional manufacturer codes in it that help diagnose car problems or will let you reprogram behavior of stuff like the door locks or
windows. Most of it does not allow you to re-tune parameters in the engine.
