Results 1 to 2 of 2
Thread: Monitoring CAN Data filters and mask
    Sep 2010
    Hi
    I want to monitor CANID So I using special filter and mask But then I want to get data using standard PIDS. The problem is when I send after following commands for example "0100" response is always "NO DATA" How could I fix that?
    atsp6
    OK
    atcmffff
    OK
    atcf4220
    OK
    ath1
    OK
    atl1
    OK
    tma
    Waiting...
    0211FFFE006400420000
    OK
    Thanks in advance
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Unfortunately, ELM327 has only one filter/mask pair. It's a limitation of its hardware. You can tweak the filter/mask bits to try to capture the traffic you want. Or can buy OBDLink, which has more flexible CAN filters.
    Vitaliy
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
