Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: STN1110 OBD to UART interpreter IC (ELM327 compatible)
  1. #11
    SuperMod - OBDII GPS Logger forum
    Mar 2009
    Los Angeles
    Hrm. I'm still confused on how this works with the bluetooth part. How can it go to sleep but still allow me to connect via bluetooth?
    Thanks!
    Gary (-;
    OBDGPSLogger, for logging OBDII and/or GPS data
    OBDSim, an OBDII/ELM327 software simulator
    mp3car forums: obdgpslogger, obdsim
  2. #12
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    I was talking about "normal", USB-only or RS232-only OBDLink. However, it can work with Bluetooth too. OBDLink would turn Bluetooth off when it senses that the engine is off ("sleep on voltage level") and turn it back on when it senses that you turned on ignition ("wake-up on voltage change"). Sheeva plug would of course need to re-discover and re-connect via Bluetooth.
    Capisce?
    Vitaliy
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    — Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
  3. #13
    Mar 2009
    Los Angeles
    Oooo, that's perfect.
    That being said, I'm confused about something, but I'll start another thread - I realised this has massively de-railed the original point of the thread
    Gary (-;
  4. #14
    May 2011
    Just tried the MP1010 code now, it worked until I got to the final page of checkout, at which point the three SPDIP-28s returned to $9.99.
    Re-entered the coupon code, hit Apply Coupon, no change.
    Also was unable to checkout in IE at all, had to use Chrome (Win7x64).
    Just FYI.
  5. #15
    Dec 2006
    Phoenix, AZ
    Quote Originally Posted by DAVEPL1968 View Post
    Just FYI.
    I placed a test order, and it worked fine (I use FireFox). Please double-check the quantity to make sure you're not trying to order more than 3. You can also try clearing cache & cookies.
    Did your order go through?
    Best regards,
    Vitaliy
  6. #16
    Constant Bitrate Zeroaviation's Avatar
    Feb 2006
    Birmingham, Al/Overland Park, KS
    Just got mine ordered! Thanx guys for giving some of us student Devs some hardware to develop with.
    Im a pilot.
    I have become a cross control stall.
  7. #17
    Mar 2010
    Quote Originally Posted by Vitaliy View Post
    We're considering adding commands to give users direct access to the CAN configuration registers. It will be some time before they are implemented, however, since there is a backlog of other features that we're working on.
    Of course, if this is a high-volume project and you're willing to pay to bump this feature to the top of the list, it can be done next week.
    Hi Vitaliy, returning on this old topic... are there any updates about the non-standard CAN rates feature?
  8. #18
    Dec 2006
    Phoenix, AZ
    Quote Originally Posted by ma_jk View Post
    Use the STPBR baud_rate command to set the baud rate. The STN11xx will set it to the closest available baud rate. You can see the actual baud rate set, by issuing the STPBRR command.
    Code:
    >STPBR 12345
    OK
    >STPBRR
    15625
    Vitaliy
  1. microOBD (OBD to UART module)
    By Vitaliy in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-22-2009, 06:31 AM
  2. Air Conditioning via OBD? (ELM327)
    By Ironicster in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-29-2009, 11:29 PM
  3. Air Conditioning via OBD (ELM327)
    Last Post: 08-26-2009, 04:45 PM
  4. Latest Build - 2013-04-25
    By ClockWorK in forum Driveline
    Last Post: 06-11-2009, 03:29 PM
  5. ELM327 VS. OBD Diagnostic Interface..need advice!
    By qewani in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-29-2009, 04:43 PM
