Of course you have to choose BT device if you use BT device
That is what its named after - short term fuel economy.
Thats an MPG calculated using a short time period (couple of seconds) - to show you your instant consumption.
Since hobd reads MAF, all you see is what your vehicle gives to hobd.
This means vehicle's ECU still informs that air is flowing (even if there is no fuel injection).
To support fuel trimming with throttle off a special PID should be used. Some vehicles report it via "PID 03" (A2 Open loop due to engine load OR fuel cut due to deacceleration ).
I don't have any information on how consistent this PID in "wild" so decided not to use it (to avoid possible jerks).
