Page 5 of 11 FirstFirst 1234567891011 LastLast
Results 41 to 50 of 109
Thread: /hobd - extended OBD2 based trip computer for WinCE/PocketPC/WinMobile/Windows
  1. #41
    Jul 2010
    Thats always a pain to setup and use these embedded CE units. I'm for sure aware of people, using hobdrive in RoadRover units (check this for example: http://www.youtube.com/watch?v=dkjfPdAtqVM). So your problem is somehow between your unit's configuration and .net35. You may try to checkout a way to 'manually' install .net (without cab). As far as I know miopocket4 has 3.5 in base and installs it as a part of itself.
  2. #42
    Feb 2009
    I saw that video and I wish I could get it working like that guy :-(
    so version 3.5 that miopocket shows, is the one that has been installed by it self? so how to install it manually? should I just copy and paste files inside the cab to the windows folder? doesn't it get deleted when I re-start the unit? because I heard that on the embedded units, hardware installs a fresh copy on the OS on restart.... i though this even would make a problem with my OBD driver and I have to keep installing the driver every single time I turn on the HU.
    There is nothing impossible in the world :-)
  3. #43
    Feb 2009
    ok I have finally could run hobd but for some reason the input panel of my windows doesn't work so I can't install the driver of my obd interface.
    does anyone know of any sort of 3rd party keyboard for wince?
  4. #44
    Jan 2011
    Quote Originally Posted by cail View Post
    Hi Cail, how do they manage to overcome the different bluetooth stack on RoadRovers? As you state at the FAQ at your page:
    In case your unit natively supports BlueTooth stack (in windows CE control panel you have Bluetooth manager and ELM adapter is visible there), then the only requirement for hobDrive is .net3.5.
    However, for example popular RoadRover multimedia units has non standard BlueTooth stack and it can't be used to communicate with hobDrive.
    I have managed to install it on a 2din chinese dvd navigator, and I am trying to overcome (if it is possible) the bluetooth conection problem.
  5. #45
    Jul 2010
    Quote Originally Posted by japetus View Post
    Hi! There two ways exist:
    First you plug USB Bluetooth dongle and use BT ELM adapter to connect with.
    Second - just use USB ELM adapter, plug it into your unit directly and instal usb-serial port driver (FTDI on most units).
    Both of these require usb-host to be available on your unit - and this is true for major part of chinese units (not sure about your particular case).
  6. #46
    Jan 2011
    Thanks Cail, that will keep me busy for a while I guess....
  7. #47
    Jul 2010
    A number of important updates in 0.8.0 version:
    - Strong usability improvements: navigation top bar, buttons improvements, better performance.
    - New screen “Fuel Details”:
    • Fuel economy and consumption in jams/idling, its price
    • Total fuel price
    • Fuel consumption on a cold engine
    • Fuel economy on a hot engine
    - New screen “Trip details”:
    • Fuel level calculations
    • Fueling records tracking
    • Odometer tracking
    • Average and max speed
    • Distance and time on remaining fuel
  8. #48
    Feb 2009
    Hi cail,
    does your programm work with Navigon 4350max ?
  9. #49
    Jul 2010
    BlackyP,
    As far as I see most of navigon's including this one are WinCE units. I don't think however they provide a direct way of running third party apps on them.
    You should search on how to start third party apps there, run hobd (probably use hobd-standalone package) and then checkout if hobd is able to see your ELM adapter via navigon's bluetooth.
  10. #50
    Feb 2009
    The ElmObdBlueToothAdapter will be akzepted, but by pairing there is a problem ... hmmmm.
  1. Milage plugin - trip meter and fuel consumption
    By festy in forum RR Released Plugins
    Last Post: 06-07-2009, 11:31 AM
  2. is a motorcycle based computer feasable??
    By psistem in forum Newbie
    Last Post: 10-15-2007, 02:54 PM
  3. FAQ: Glossary of Terms
    By Bugbyte in forum The FAQ Emporium
    Last Post: 11-07-2006, 05:00 PM
  4. AMD based computer
    By StreetStyleTT in forum General Hardware Discussion
    Last Post: 09-03-2005, 05:57 AM
  5. OBD2 interface based on Max232/Max233??
    By Maddog_rvo in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-08-2005, 05:11 PM
Tags for this Thread
