Page 7 of 11 FirstFirst 1234567891011 LastLast
Results 61 to 70 of 109
Thread: /hobd - extended OBD2 based trip computer for WinCE/PocketPC/WinMobile/Windows
  1. #61
    Jul 2010
    Glad to hear it works so preciesly. It was initally tuned agains 1.8 accent and similar. It basically do not depends on engine displacement - it more depends on rpm/load curve.
    You may try to enter "engine load coefficient" in settings with something like 0.90 or 0.95 to remove these 0.5 liters - this requires no rpm curve editing - it'll be just scaled down.
    Under trimming do you mean turning the consumption curve coefficients? I've only made this 'emperically' by hands, looking at detailed charts of sensor data from vehicles and comparing this with average consumption. (I unfortunately don't have direct access to any diesels).
    I have an idea to implement a 'playback' mode where the curve could be automatically applied to already recorded sensor data - and thus automatically see how curve editing impacts calculated fuel consumption..
  2. #62
    May 2011
    Dvd gps
    Quote Originally Posted by Yocee84 View Post
    Hi cali!
    Good job your program. I have a chinese 7" gps, and elm based bluetooth obdII reader, in my e12 corolla, and almast ewerything is fine, but little lagging.
    I want one feature for this software (or two...)
    -Auto sleep the pna when the power off (like an igo8)
    -hotkey to switch to the navigation software.
    When you want implement this, i promis buy a full version.
    I have just got a Unit that runs iGO etc. Do you mind giving me info on how you got this software to work. Looks interesting
  3. #63
    May 2011
    Hi!
    witch software you ask?
  4. #64
    May 2011
    Hi Cali!
    I how this "software" for you: http://www.megaupload.com/?d=8MEZKPQO
    This exe is shut down the pna, but when charger is on, the pna is swich back to work. please implement this "button" to software.
    And.
    The 0.9 version of the software is wont work for me.
    Not work on my notebook (win7) and my 7" chinese gps, with bluetooth. But the 0.8 is good.
    the 0.9 not find the bt obdII reader, or when find, not able to connect.
    And please help:
    What is the best selection for 1.4 vvt-i toyota corolla e12 2003?
  5. #65
    May 2006
    Bluetooth GPS ?
    Hello
    Just wondering if any one has been able to get this working on a Bluetooth enabled GPS ?
    Thanx
    DM
  6. #66
    Jan 2008
    MD, USA
    Subscribing...
    CarPC: Mini-MAC Coming Soon!
  7. #67
    Jul 2010
    dcjb,
    apmostert ,
    On your unit you should have an option to run external software from SD card. It could be named like "External navigation software".
    You then put hobd (standalone version) onto your SD card and point out "hobd.exe" as an external software to run.
    Alternatively, you should read on how to access winCE shell directly on your hardware. That depends.
    Yocee84, does it works this way on your unit? Because not many PNAs have an option to autostart upon charge activated.
    I'll see what could be done on this.
    You should try "Toyota" vehicle type and "Injector" MPG calculation method. if these not working, MAF will work for sure.
  8. #68
    May 2011
    Quote Originally Posted by cail View Post
    dcjb,
    Yes, it works in my 7" chinese pna. maybe the Igo (primo, amigo, 8 ) use same tech.
    thangs for the settings.
    the 0-100 acc test is only the full version?
  9. #69
    Jul 2010
    It seems the program at the link just suspends the unit - nothing more.
    Can you try to manually suspend your unit and then plugin the power - will it wakeup? If yes, then the functionality is easy to implement, just suspending you unit when no power.
    yes. you may read for more differences on the site.
  10. #70
    May 2011
    Yes, i try it, and it works manualy. But the 0.9 version dont work for me.
  1. Milage plugin - trip meter and fuel consumption
    By festy in forum RR Released Plugins
    Last Post: 06-07-2009, 11:31 AM
  2. is a motorcycle based computer feasable??
    By psistem in forum Newbie
    Last Post: 10-15-2007, 02:54 PM
  3. FAQ: Glossary of Terms
    By Bugbyte in forum The FAQ Emporium
    Last Post: 11-07-2006, 05:00 PM
  4. AMD based computer
    By StreetStyleTT in forum General Hardware Discussion
    Last Post: 09-03-2005, 05:57 AM
  5. OBD2 interface based on Max232/Max233??
    By Maddog_rvo in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-08-2005, 05:11 PM
Tags for this Thread
