Page 9 of 11 FirstFirst 1234567891011 LastLast
Results 81 to 90 of 109
Thread: /hobd - extended OBD2 based trip computer for WinCE/PocketPC/WinMobile/Windows
  1. #81
    Jul 2010
    About the sensor, don`t know which one, but the value is on second screen on top in the middle, thats current consumption in that moment.
    Thats an instant fuel economy. Basically it doesn't reflect your real car's efficiency. To understand real efficiency you have to look at the central sensor - "fuel economy trip". It reflects overall economy over long period of time.
    Reason why is this value important to me is i don`t have factory trip computer in my car. This car is equipped with DPF filter.
    Thanks for sharing, really interesting.
    With this, I still recommend you to read carefully user's manual and calibrate your consumption - because without this all measures will be quite an "abstract" numbers.
  2. #82
    Jul 2010
    New 0.9.7 version:
    - Improved short and instant fuel consumption sensors. They are now smooth and more reliable.
    New configuration for these sensors is available: own idle speed, and option should the FC should include idling into calculations.
    - Fuel consumption can now be affected by engine deceleration state (fuel trim), LTFT sensor value or current Lambda(AFR) value.
    These modes are disabled by default and could be enabled from vehicle settings screen.
    Settings only available in hobDrive.
    - New PIDs: CommandedEGR, EGRError, Commanded_EVAP
    - New System Settings Option to hide "HUD" button (hobdrive only)
    - Help screens added to some of parameters. To open, click highlighted parameter labels.
    - Portrait orientation now uses same sensor layout as landscape (no mirroring).
    You may restore old behaviour via system option "Mirror elements".
    - Ukrainian translation (thanks to Mike)
    - Italian translation (thanks to Emiliano)
    - Fixed empty space at the bottom screen side in Windows Mobile and PDA systems.
    Fix may have side-effect on WinCE - it may be reverted with "Show system task bar" option.
    - Improved compatibility with widcomm-based devices
    - Fixed "injector performance" config parameter not being used.
    - Fixed bug in data track, when accumulated sensors actively persisted though they should not.
    If you feel hobdrive consumed alot of storage space, please check "track" folder within hobdrive's folder and
    cleanup it manually.
    - Fixed potential issue on .netcf3.7
    - Increased connection retry interval (now in background mode it is 1min, in foreground - 10sec)
  3. #83
    Jun 2011
    Honda Diag-H
    Is it possible to integrate support for the Honda Diag-H Diagnostic protocol into HobDrive ?
  4. #84
    May 2011
    Hi!
    unfortunatly, but the new version wont start my pna. just sent a pop-up its say some .net problems (sorry but my pna has a portugese firmware, and i dont understand it.
    this version not have standalone pack?
  5. #85
    Jul 2010
    Quote Originally Posted by Yocee84 View Post
    All versions are released with 'standalone' pack. Find a link at http://hobdrive.com/hobd
    Mozart4000,
    Thats probably not realistic - right now working only with ELM.
  6. #86
    Jul 2011
    Binatone T430
    Hi All!
    Anyone try to connect to Binatone T430 to Bluetooth OBD? I love this HOBD and running nicely on my XDA orbit and Bluetooth OBD. I was installed the HOBD to my Binatone T430 (it has a bluetooth ) but when I try to connet it sad "Bluetooth Not Supported"
    Any idea or same experience or solution?
    Thank You
  7. #87
    May 2011
    okay, it works! thank you! this version is great, and fast. one more thing... the automatic shut down and start...
  8. #88
    Jul 2010
    nagyzizi,
    Your unit probably do not have full BT stack. Try to search BT manager for some option like 'keep BT always on'. If still HOBD reports "not supported" - your only case is to use usb-host to plugin BT dongle or USB-ELM adapter.
    Yocee84,
    Working on that!
  9. #89
    Jul 2010
    Yocee, you may try this (unofficial) build with extra option available to auto suspend if no AC power is detected:
    http://hobdrive.com/download/hobd/hobd-0.9.12.wince.zip
    http://hobdrive.com/download/hobd/hobd-0.9.12.win32.zip
    http://hobdrive.com/download/hobd/hobd-0.9.12.wince.cab
    http://hobdrive.com/download/hobd/ho...standalone.zip
    A list of some other updates in there:
    - New UI Gauges: colored bar and colored round speed bar.
    - New dialog to enter maintenance records.
    - New screen "Events and Fillups" with data analysis and review abilities.
    Trial HOBD is limited with latest 12 records analysis.
    - Option "Keep taskbar" is now enabled again by default (caused problems with not visible low area with buttons on some devices)
    In case you see an empty space at the bottom of the screen on your device (taskbar area), you may disable this option explicitly
    to allow hobdrive use this area.
    - Workaround for possible unexpected system date change (statistics totally screwed if that happened)
    - Reconnection Time intervals are now configurable.
    - New option (disabled by default) to suspend device after hobdrive detects the external AC power was detached
  10. #90
    Jun 2011
    Template Honda Prelude 97
    Is there someone who creates a template for a Honda Prelude 5th gen from 1997?
    It's OBD2a (ECU P5n) with a 3pin K-line port. In the program only templates are availabe for
    Toyota and Fiat. I tried them all with an ELM327 plus 3pin to OBD adapter, but none is working.
  1. Milage plugin - trip meter and fuel consumption
    By festy in forum RR Released Plugins
    Last Post: 06-07-2009, 11:31 AM
  2. is a motorcycle based computer feasable??
    By psistem in forum Newbie
    Last Post: 10-15-2007, 02:54 PM
  3. FAQ: Glossary of Terms
    By Bugbyte in forum The FAQ Emporium
    Last Post: 11-07-2006, 05:00 PM
  4. AMD based computer
    By StreetStyleTT in forum General Hardware Discussion
    Last Post: 09-03-2005, 05:57 AM
  5. OBD2 interface based on Max232/Max233??
    By Maddog_rvo in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-08-2005, 05:11 PM
Tags for this Thread
