Results 1 to 2 of 2
Thread: MAF accuracy
    Newbie split63's Avatar
    Feb 2009
    Question MAF accuracy
    MAF sensors produce results which factor in temperature, humidity, and altitude. They seemingly make the job of determining the Mass of Air flowing into the engine easy.
    However, I'm wondering how accurate or linear they are. For example, let say a known mass of air is passed through the MAF sensor. How accurate would the result be if the temperature was then varied from say 0F to 140F? Likewise with the humidity and pressure (Alt)?
    Any one have any data?
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Quote Originally Posted by split63 View Post
    Standard OBDII PIDs include ambient air temp, intake air temp and barometric pressure, so I would "suspect" that those might be taken into account. Don't know about the humidity.
    VegasGuy
  1. Calculating MPG from VSS and MAF from OBD2
    By maeliosa in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-25-2014, 09:29 AM
  2. DIY 1cm accuracy RTK-GPS
    By Fiberoptic in forum Mp3Car Blog Talk
    Last Post: 11-30-2009, 12:00 PM
  3. MAF value
    By lucal in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-27-2009, 11:14 AM
  4. GPS and Accuracy
    By sviyer in forum GPS
    Last Post: 10-11-2006, 10:16 AM
  5. Accuracy of Rikaline 6010
    By justintime in forum GPS
    Last Post: 06-06-2005, 06:26 AM
