Results 1 to 2 of 2
Thread: OBD 2 - Dodge 47re tranny
    Dec 2010
    Hi, I have a 1998 Dodge 2500 with the 12v Cummins (mechanical, not computer controlled). I'm looking to insert custom PID's into Torque on my Android phone so that I can read the Transmission Temp.
    Could someone lend a hand with this? How can I find out the PID perameters?
    I've got some OBD2 software for my phone, and a connector. I can read the following out of the box:
    Speed (ECU)
    Intake temp
    RPM
    Coolant temp
    Throttle (although my foot off the pedal gives a throttle of 16.9%, and floored I get about 89%)
    Load (again, not sure if this one reads correctly - seems close anyways)
    I can program in anything else I want as long as I have the following information (this is where I'm thinking I'd like to get trans temp if the ECU reads it):
    OBD2 PID (in hex)
    Long Name
    Short Name
    Minimum Value (typically 0)
    Maximum Value
    Scale Factor
    unit type
    equation (eg: a*b+20)
    Thanks,
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    The best way is to get your hands on the SAE J1979 spec.
    If you don't want to spend the $80 (or whatever), you can refer to this list on Wikipedia:
    http://en.wikipedia.org/wiki/OBD-II_PIDs
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
  1. Latest Build - 2014-06-11
    By ClockWorK in forum Driveline
    Last Post: 06-11-2009, 04:29 PM
  2. OBD II connector on an OBD I car
    By HearseNurse in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-23-2009, 10:52 AM
  3. OBD or special hardware?
    By Jirka Jirout in forum General Hardware Discussion
    Last Post: 03-04-2007, 06:01 AM
