Results 1 to 7 of 7
Thread: CAN bus (NOT OBD) data - reverse engineer? Or enhanced OBD PIDs?
    May 2008
    Hi,
    I've developed a bit of an obsession with trying to get performance data out of the ECU/PCM on my Ford truck. Mainly, I wanted to come up with some sort of instantaneous fuel economy reading. Since I have a new (6.4L, CRD design) diesel engine, it's impossible to get this information from the standard OBD PIDs. I've been doing a lot of research, and it seems like the data *may* be available on the engine CAN Bus (HS-CAN, 500Kbps). I have access to the ford engine manual and workshop manual, which tells which modules in the vehicle are on which busses. It also gives useful information, like telling me that the turbocharger boost gauge on the instrument cluster is fed over the 500 Kbps HS-CAN bus.
    I've found a few references online to people reverse engineering the CAN bus messages and figuring out what at least some of them are. I also have a list of the Enhanced PIDs from Ford, but it just lists the name of the PID, the abbreviation, the scaling, etc. but not the actual numeric PID.
    So, I was wondering...
    1) Does anyone know of a source for information like this?
    or...
    2) does anyone know of a website, forum, mailing list, etc. for crazy people like me who are trying to reverse-engineer stuff as opaque as the vehicle-specific CAN messaging?
    Thanks,
    Jason
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Why not use one of the other two threads your active in asking similar questions? Cross posting is very difficult to follow and kind of clutters up the board.
    Forgive me if I misunderstand but this post seems awefully similar:
    I'm also very interested in getting data off of the CAN BUS (specifically HS-CAN) from a Ford vehicle... but I'm working with a F350 truck with diesel engine (2008, 6.4L).
    Has anyone found a source for the frame identifiers (IDs) used on the HS-CAN?
    May 2008
    Yeah, I'll admit, the message is similar. It seemed to me that the other thread was trending in the direction of OBD, and even after some pretty exhaustive searching (both here and on google) I haven't been able to find any threads directly relating to (or dedicated to) getting HS-CAN data that's not available via OBD...
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    I wish I could help you with this but it's beyond my scope of knowledge on CANBUS. (Which is pretty limited...) You likely can get some more answers out of Vitalty in the other thread. Good luck with it!
    Mar 2006
    Colorado, but Canadian!
    I have spent the last 11 months reverse engineering the CAN protocol in a different vehicle. It is undoubtedly the most advanced and electrically complex vehicle in mass consumer production, so I am not sure how much less information your truck will have. But I basically used a Fusion Brain and another micro controller on a breadboard, hooked it up in passive sniffing mode, and monitored every transaction. Every message was printed, timestamped and saved to my laptop. I then wiggled switches pressed buttons, drove around, and other stuff. Once you figure out some of the basics, it gets easier and easier.
    I am an EE and have been doing this sort of thing for a while, so I have no idea what your background or expectations are. But almost a year of working on it between 15 and 30 hours a week and an analytical mind has decoded the mystery of my CANbus.
    1.9in x 2.9in -- 47mm x 73mm
    Feb 2006
    Melbourne, Australia
    Hello Mate,
    We have a local Lad Down Under, who did a lot of good work on decoding CANbus messages on our Aussie Ford Icon car, the Falcon.
    It should give you a good starting point, lots of reading, but will get you going.
    Have fun!
    F6 Tornado Project Log ; HP Blackbird Watercooled Server
    Beta Tester for Centrafuse and 3dConnexion (No business affiliation with either)
    Jul 2005
    Michigan
    To say the least, there is a huge learning curve involved in reading CAN Bus data. I have been doing this professionally for the better part of 5 years, and still there are many new things that surprise me.
    Check out a my blog, where I attempt to shed light on the reverse-engineering process at www.canbushack.com
    Hack your car's CAN BUS at www.canbushack.com
  1. Replies: 444
    Last Post: 10-21-2014, 05:50 PM
  2. Renault "Tuner List" Head Unit/CD changer hacking - Controls
    By Vicne in forum Hardware Development
    Last Post: 10-30-2012, 07:09 PM
  3. Getting data from CAN bus
    By DrLomax in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-10-2008, 01:42 PM
  4. Class 2 data bus? J1850?
    By Rickertsen2 in forum Hardware Development
    Last Post: 07-15-2005, 04:28 PM
  5. Pinout Color Codes / Tables
    By gummybear in forum General Hardware Discussion
    Last Post: 05-12-2005, 03:05 AM
