Page 5 of 5 FirstFirst 12345
Results 41 to 43 of 43
Thread: Multiple ECU responses
  1. #41
    Jan 2011
    Okay Thanks! I'll try it ATSH for KWP and ISO...
    Filtering would be an Idea but I don't know how in obj C
    I have every Message in an String.
    Thanks!
  2. #42
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Quote Originally Posted by klist View Post
    Thanks!
    You know the third byte is the source address. If the source address does not match your selected ECU, throw the string away.
    Vitaliy
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    — Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
  3. #43
    Dec 2011
    Quote Originally Posted by remus08 View Post
    Hi,
    I don't know what you're using for your experiment but each ECU has its own ID (identifier). For a CAN bus based vehicle, 0x7E8 is engine and 0x7E9 transmission
    Solution 1 : You can filter what you're looking for
    or
    Solution 2 : Just talk to the engine ECU
    If you give more information, maybe I will be enable to answer for precisely
    Where can i find a list of identifiers and their meanings ?
  1. Replies: 0
    Last Post: 04-27-2009, 04:36 PM
  2. Multiple ECU responses
    By mctodd00 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2008, 07:16 AM
  3. ECU passes emission test with bad O2 reading?
    By Leandra in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-14-2008, 09:50 PM
  4. Replies: 3
    Last Post: 08-11-2007, 02:22 PM
