Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Problems with the ELM-327
  1. #11
    Jan 2009
    Bugbyte,
    I'm not sure about the model, but here is the direct link to the unit: http://www.mo-co-so.com/USB-ODB-II-E...bd-327-usb.htm
    Thanks,
    DominicanJB
  2. #12
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    You should have gotten this one instead.
    http://www.mo-co-so.com/Scan-Tool-EL...-sca-elm-5.htm
    Also available from MP3Car:
    http://store.mp3car.com/ElmScan_Comp..._p/com-101.htm
    Or better yet, get an OBDLink SX (coming soon to MP3Car).
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
  3. #13
    Jan 2009
    I need technical help. Not a salesman.
    DominicanJB
  4. #14
    Dec 2006
    Phoenix, AZ
    Quote Originally Posted by dominicanjb View Post
    DominicanJB
    Suit yourself, DominicanJB. ELM327 clones are hit and miss. Sometimes they work great, sometimes they don't work, and sometimes they sort of work (which is worse than if they didn't work at all, this thread is a great example why). So what you buy depends on how much you value your (and other people's) time.
    Yes, I am biased, but that is only because (A) ELM327 users come to our forum for support in droves (because the clones ship with ScanTool.net v1.13 software and people think we're the manufacturer) and (B) the tools I recommended, pass a rigorous quality assurance check. I know this, because I helped design and build the testers, write the test scripts, and put together the test procedure.
    I can totally sympathize with people who are trying to save money, and I don't blame you for buying the cheaper alternative. You can console yourself by the thought that your experience may help other folks to avoid the same mistake.
    Vitaliy
  5. #15
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Heh, for $5 more you could have gotten support from the maker right here. I have the same clone. Mine reports version 1.5a which doesn't exist, so my software has a special case to revert to 1.2 specs which is all it supports. Who knows what all of them report. It's enough work to keep up with ELM. But just like overstated battery capacities and SD cards, China is number one.
  6. #16
    Low Bitrate remus08's Avatar
    Mar 2010
    FRANCE
    The seller where you bought this ELM is not even able to provide you USB driver for Vista and Seven...
    Chineese seller of OBD product sucks and I know that I said!!
    Try to find a local re-seller which will most of the time offers a good software to use your interface
    so yeah, agree with Vitaly...
    i think OBDLink SX includes OBDWiz ...
  7. #17
    Jan 2009
    Elm-5
    I bought the ELM Scan 5 USB version and works just fine. I bought it from the same place I bought the 327. I returned the faulty 327 and got full credit, so I only paid for the price difference. If copies and/or clones of the 327 are being sold rampant with a chance that it might not work, I suggest that there should be more awareness so that others don't lose their money. Instead of learning about this in different threads scattered around, there should be a sitcky thread with flashing fonts alerting others about this. I consider myself lucky that I didn't lose my money, but others might not be as lucky.
    Thanks,
    DominicanJB
  1. elm 327 interface with laptop problem
    By gowing238 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-31-2010, 05:58 PM
  2. ELM 327 in windows 7?
    By bigbuffs in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-16-2009, 09:06 PM
  3. Replies: 33
    Last Post: 03-28-2008, 02:18 PM
  4. Harddrive problems (booting)
    By Axxess in forum General Hardware Discussion
    Last Post: 05-15-2007, 04:13 PM
  5. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 01:55 PM
