Results 1 to 3 of 3
Thread: CAN Mode 3 DTCs
    Jan 2011
    CAN Mode 3 DTCs
    Hi!!
    I am trying to implement the CAN mode 3 (DTCs). I am using the software ScanMaster-ELM and Digimoto to do the tester.
    When I send a request 7DF 8 01 03 00 00 00 00 00 00 where 7DF is ID, 8 = n bytes of the CAN frame, 01 additional bytes, 03 is the mode 3
    I want to response, for example, with 7E8 8 04 43 01 02 34 AA AA AA, where 7E8 is ID, 8 n bytes, 04 additional bytes, 43 is mode 3 response, 01 number of DTCs, and 02 34 is the DTC P0234.
    When I send this response to the programs, ScanMaster and Digimoto do not detect the response.
    What could be happening?
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Are you trying to build an ECU simulator?
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    Jan 2011
    Yes, I am trying to build an ECU with all modes with CAN protocol
  1. Differences between the DTCs mode 3 and DTCs mode 7 in CAN
    By proyectanteATE in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-02-2011, 05:10 AM
  2. AUDI CONCERT 3, MP3 OEM RADIO HACK. Help!!
    By coucouillu in forum Hardware Development
    Last Post: 01-16-2011, 04:53 PM
  3. Quest for 800x480
    By ptk in forum LCD/Display
    Last Post: 01-04-2010, 10:42 AM
  4. Reading DTC's from Modules OTHER than PCM
    By Lukeyson in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-21-2007, 08:11 PM
  5. BASIC Stamp question
    By Banderon in forum General Hardware Discussion
    Last Post: 05-07-2004, 08:33 AM
