Results 1 to 10 of 10
Thread: CAN Mode 0x06 Multi-line messages
    Jan 2011
    Hello!!!
    I am building for CAN protocol an ECU. When I send the request of the parameter 1 of the mode 6, which it is supports for my ECU, 02 06 01 00 00 00 00 00.
    The response according to the example of the SAEJ1979 must be:
    46 01 01 0A 06 60 06 60 06 60
    Where 01: OBDMID
    01 Standardised Test Id
    0A Unit And Scaling Id: Voltage
    06 60 Test Value
    06 60 Minimum Test Limit
    06 60 Maximum Test Limit
    The problem is that in the CAN frame I can transmit 7 data bytes.
    I have tried to send 06 46 01 01 0A 06 60 AA
    Followed by one:
    05 46 06 60 06 60 AA AA. But the tester does not interpret anything.
    How are bytes followed in CAN transmitted? Is necessary some flow control frame as for example in the mode 9 that 7E0 30 00 00 00 00 00 00 00 is used?
    Note: the first byte of the showed messages indicates the number of additional bytes that go in the message.
    Thank you!!
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Which version of J1979 do you have? Mode $06 for CAN is described in great detail in the current version.
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    Jan 2011
    I have SAEJ1979 REV. APR2002.
    Is there some more recent version?
    Oct 2008
    Yes, a version from 2007 with a lot of new pids and a new service ($0a) and a version from 2010.
    Jan 2011
    HI p2psmurf. How can I obtain these new versions?
    Sep 2008
    Jan 2011
    Thank you Aberk, but free?
    Oct 2008
    Other than buy from the SAE? NO idea.
    Low Bitrate remus08's Avatar
    Mar 2010
    FRANCE
    Hi all,
    Opsss, there is a new version. I've bought the 2007 may revision there is one year ago, and I'm not so much enthusiasm to buy the new one...
    Mode 0A is already included in the 2007 revision...
    Somebody can tell me where find revision history?
    How many page fot the 2010 version?
    Thanks ahead of time!
    Constant Bitrate joeyoravec's Avatar
    Oct 2005
    Livonia, MI
    Quote Originally Posted by remus08 View Post
    Somebody can tell me where find revision history? How many page fot the 2010 version?
    In each publication, a black bar in the margin indicates areas that contain technical changes (as opposed to english/editorial changes). As far as I know, there's no other sort of revision history. Here's a page with lots of contact info to ask these questions though: http://www.sae.org/about/contact/
    I agree it's annoying if you just purchased the 2007 publication, but it's about $60 and that won't break the bank.
