Results 1 to 5 of 5
Thread: PID 04 LOAD value
    Low Bitrate remus08's Avatar
    Mar 2010
    PID 04 LOAD value
    Hi all,
    I'm trying to understand what means this PID... Standard said that is a calculation of pourcentage of torque used currently by the engine
    I saw this PID equal to 15% for my gasoline car at idle which can be possible
    but I saw a 40% value for a diesel car at idle too
    If someone can help me to clarify this it would be great
    Constant Bitrate joeyoravec's Avatar
    Oct 2005
    Livonia, MI
    The original equation works for gasoline motors: current airflow / peak airflow, at this rpm, adjusted for barometric pressure, expressed as 0-100%. The latest publication adds that second equation for diesel motors that aren't really based on airflow. In either case the value represents the engine's loading; the delivered torque versus the maximum available torque for the current conditions.
    I'm not sure if I can explain the 40% that you're seeing.
    Newbie MX5_Carputer's Avatar
    Mar 2010
    I think of it like this:
    Petrol load = [Airflow / Airflow max@current eng speed]
    Diesel load = [Torque / Torque max@current eng speed]
    The difference in notation is because diesels generally run unthrottled.
    40% at idle is normal for most passenger vehicle diesels in Europe (1.6 - 3litre say). At idle ~ 750 rpm you are required to make 40% of your available torque just to run ancilliaries etc... check your torque map and you will realise at this engine speed torque is low so 40% is still actually a low torque value.
    Mar 2010
    Thanks for the answer... I guess i've understood, but yes it's wierd, actually PID 11 is more interresting to known the driver demand (what I looking for...)
    Aug 2010
    Hi guys,
    I recently got a Citroen Saxo 1.1 for testing and it reads 5% calculated load value on idle when most vehicles do 12-20%.. Is sth wrong with that? THe car is running great.. And at WOT it reads 100%..
    The protocol is EOBD, how can I find out which specifically is, ie ISO, KWP etc?
    Is there any possibility that its load value is calculated differently than we know therefore it reads that low value?
  1. Failed to load control 'Flash' error on load
    By Vinci in forum Road Runner
    Last Post: 04-21-2009, 11:51 AM
  2. convert tray load to slot load...
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 09-28-2007, 11:35 AM
  3. Get a load of this guy?????
    By HummDinger in forum FrodoPlayer
    Last Post: 01-31-2005, 11:48 PM
  4. load soft ware to usb hard disk then load to comp
    By tracker92 in forum General Hardware Discussion
    Last Post: 08-29-2004, 07:57 PM
