Results 1 to 5 of 5
Thread: OBD-II Switching
    Jun 2005
    OBD-II Switching
    OK here is my dilema
    i have 2 units that i would like to have plugged in all the time in, now i know they will both argue over who has priority etc.
    so my guess was to have a rocker switch on the power line from the OBD so i could allocate which one would have access to the ecu....
    i currently have the following items in the car
    HKS Camp2 Unit
    OBDII reader
    any thoughts or suggestions......
    Jun 2005
    any ideas people ?
    Constant Bitrate dna59's Avatar
    Jul 2010
    Belize City, Belize
    Go to the junkyard and get a OBDII plug and wire it up along w/ the one that's already in there? Then put a switch on the power feed for it. In theory sounds like it would
    Jun 2005
    That's my thoughts well not going to bother with extra plug just hard wire a unit before the plug lol
    Jul 2005
    I've had multiple tools connected many many times with success. Shouldn't be an issue provided the hardware you are installing doesn't suck.
    Depending on what protocol your car uses, you may just be able to have them both connected at the same time. Both modules may request the same info at the same time, but the car will just think its coming from one module just really fast. If it can handle serving the information then it will; if it can't, it won't.
    Good luck.
    Hack your car's CAN BUS at
  1. Switching from Ubuntu to OSX
    By ThePistonDoctor in forum MacCar
    Last Post: 07-27-2010, 04:45 PM
  2. DIY Switching Between Inputs?
    By JasperVal in forum Input Devices
    Last Post: 02-14-2008, 03:42 PM
  3. Considering switching to CF: some questions
    By S4Per in forum Centrafuse
    Last Post: 01-04-2008, 09:01 PM
  4. M1-ATX not switching on motherboard
    By spaceman in forum Power Supplies
    Last Post: 03-03-2005, 07:43 AM
  5. Switching over to MS agent
    By 0l33l in forum PowerVoice
    Last Post: 11-07-2004, 01:30 AM
