Results 1 to 10 of 17
Thread: Need input on Android app: OBD Dashboard
    Apr 2011
    Hi!
    I'm the developer of an OBD2 app for Android: OBD Dashboard. This is a project that I've started for myself and after a while I've decided to try to make it public.
    So far, many features are missing (I do this on my spare time), but I would like to get some feedback from more users. My testing is limited to a generic chinese ELM327 clone on a Brazilian Peugeot 206 using a Motorola Milestone (Motorola Droid on US).
    There are other nicer OBD apps, but I wanted to implement this myself to make sure everything was as optimized as possible. Next features to be implemented are nicer gauges and UI, and some other PIDs.
    I would say the main difference between this app and other apps is efficiency. Everything is done as efficiently as possible. For users this means that you battery will last longer and information will be shown faster.
    There are some interesting features too: auto connect/disconnect when a car dock is used is one of them. Logging is also available.
    Known issues are: sometimes it doesn't connect properly on my phone. I'm not sure if it's my fault or the phone's fault, but I'm looking into it.
    I would appreciate if you guys can give some feedback. Does it work correctly for you? Is it good or is it bad? Why?
    The app is available on Android Market: https://market.android.com/details?i...=search_result
    Some basic usage instructions are available here: http://obddashboard.blogspot.com/
    Basic screenshot:
    BTW: I hope I'm not infringing any rules here. I'm not trying to sell it (yet), just want some feedback from users .
    Apr 2011
    I have been making some improvements internally on the software, and also on the UI.
    You can now use it in both portrait and landscape mode (even though you are limited to the 2 gauges available).
    The title now shows the update rate (ex: 4.0 Hz).
    Here's the new portrait design:
    Logging is a little bit faster too. It wasn't a problem before, but as I said before all significant code is very optimized to avoid delays on showing information.
    Currently there are no optimization being run on the scantool because my cheap chinese OBD doesn't behave properly with some commands. I'll be able to work more on this when my ObdLink device arrives.
    Has anyone tested it? I'm eager for feedback.
    Newbie preet's Avatar
    Sep 2009
    Canada eh
    Hey
    I don't have an android phone to test your app out, but I'm curious about your driver implementation for your ELM327 clone. I'm trying to do something similar, (using Linux, not Android), and I was curious as to the max stable refresh rate you were able to achieve.
    Also, are you talking to the device synchronously (ie. fixed refresh rate), or asynchronously?
    Regards,
    -Preet
    Apr 2011
    For the 327 clone, it's better to leave it at default configuration. Trying to improve things using specific timing command only made it worse.
    Communication is done as fast as the scantool allows: you should send a command (a 01 0C for example) and process the data. As soon as the tool is ready (">" is sent) you can send the next command.
    On the small blue ELM327 clone (don't know if it's the same as yours) I'm achieving between 3.8 and 4.0 updates per second, using default configuration. If I try to improve things changing adaptative timeout, or setting a fixed timeout value, it's behavior is not as expected, and ends up being worse.
    Yesterday my OBDLink Bluetooth scantool arrived. Without any changes I achieved 5.8 updates/second. Using a few tricks that might not work with everyone I was able to get it to ~10 updates/second. It's really worth it (so far). These tricks are not on the published version.
    By the way, if someone is reading this: I've added mph support on the latest version. I was really stupid of not thinking about this before publishing it online.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    How are you connecting the ELM to the Android phone. Thats something i never quite understood. I have a wifi Kiwi device but i was under the impression its only supported by iPhones .
    Live mp3Car Facebook Chat
    Sep 2009
    Canada eh
    I'd assume the connection would be done with bluetooth?
    nicolas, I was able to improve my max refresh rate by increasing the baud rate. The drivers I'm using for serial comm go up to 115200 and the response rate seems to get slightly better as I increase the speed. The ELM default was 38400, and I thought this was the hardware limit, but at least with my device, this wasn't the case. I have a wired clone: http://www.dealextreme.com/p/obdii-u...e-dc-12v-42827
    My best refresh rate is around 40 ms right now, as I get lower I see more and more errors, though not really sure if this is due to the way I'm talking to the device or not. Do you ever find that the response indicator ('> character') sometimes doesn't occur? I'm trying to improve the refresh rate to below 30ms, that way people wouldn't be able to notice any lag in visual updates (29fps, etc).
    Anyways, sorry to derail your topic, the software looks awesome
    -Preet
    Jun 2009
    I'm looking for developers to help work on an open-source library for Android. libvoyager. It already has code for OBDII, CAN, HSCAN, SWCAN and more. If you join up we can work together and put some cool ideas to work!
    Jan 2008
    MD, USA
    Will check it out and let you know.
    CarPC: Mini-MAC Coming Soon!
    Apr 2011
    First of all, on the recent versions I've added MPH support. This was a huge mistake by my part, as on my country we only use km/h. Sorry for all US and UK folks! The app will try to automatically choose between those units based on your language settings, but you can override it on Preferences.
    I'm waiting on your opinions! I'm working on new stuff and improvements. If you have suggestions on what is more important, just post it here, I'll see what I can do. This week has been complicated on my daily job, so I couldn't work much on the OBD app.
    Thanks!
    Preet,
    Yes, communication is done with bluetooth (just like a serial port).
    I haven't found any cases where '>' wouldn't be sent by the scantool. So far I've only tested it personally with a cheap ELM clone (the smaller, blue one) and with an OBDLink Bluetooth (which works much better!).
    Would you mind telling me what protocol and car are you testing on to achieve 40ms refresh rate? That's pretty good. My best so far is only 10 updates/second, still a work in progress.
    The current free version of my app doesn't use any special "tricks" to improve refresh rate on the scantool, but I'm testing some of those options on my personal version.
    Thanks!
    Jun 2010
    Syd, Australia
    HI Nicolas,
    Looks great so far.
    Suggestions:
    1. Option to read error codes and also to extinguish Mil lights
    2. skinability
    Also for me personally, I like to keep an eye out on batt voltage (when car is off)
    And is this your scanner?
  1. Input Input Input Show Me Your Devices!
    By SjLucky in forum Input Devices
    Last Post: 03-07-2012, 04:27 AM
  2. dashboard
    By tja in forum RR Skins
    Last Post: 09-08-2008, 09:04 PM
  3. Best Dashboard Ever!
    By SevKING in forum General MP3Car Discussion
    Last Post: 03-31-2006, 08:03 PM
  4. Dashboard Advice...
    By mikey3521 in forum Newbie
    Last Post: 01-18-2006, 09:04 AM
  5. what would your ideal dashboard be like?
    By stapan in forum General MP3Car Discussion
    Last Post: 08-24-2005, 11:11 PM
