Results 1 to 6 of 6
Thread: ELM327 Trouble Codes
    Apr 2011
    I am interfacing with the ELM327 and following the ELM manual, it states a request of 03 should have a response such as:
    43 01 33 00 00 00 00
    So the 6 bytes following the 43 are the response trouble codes.
    Well, I pulled the MAF cable off on my test vehicle to make it throw a light, and when I issue an 03 command, I get back:
    43 02 01 02 01 13
    So it would seem the codes would be 0201 and 0113, but this is not the case.
    The actual codes are 0102 and 0113. Is the first byte after the 43 supposed to be ignored? If so, then am I to assume that if there were 3 codes set, the response would be something like: 43 02 01 02 01 13 00 00
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    That's odd, mine returns an odd number of bytes, the 43 header, and then an even number of bytes (two for each trouble code. If I have three codes, I'll see 43 01 02 01 13 03 15
    RevFE
    My Shop
    Apr 2011
    It is strange...
    Anyone else have any ideas why?
    Apr 2011
    Quote Originally Posted by malcom2073 View Post
    So if you had 2 codes would it show you 43 01 02 01 13 00 00
    Apr 2011
    I did some testing on my vette and unplugged the maf and elec throttle control and got the following nice response:
    43 01 02 11 20 12 20 \r43 15 14 15 15 00 00
    I did the same on the mazda and I got this garbage (I dont see these values mentioned anywhere in the ELM manual):
    00A
    0:430401020113
    1:01230222000000
    As you can see the 0: is only 5 bytes following the 43. But what is this 0: and 1: anyway? I dont see these mentioned in the ELM manual. WHat is the 00A header?
    Jul 2011
    Hi..
    Maybe this will help you....
    In CAN protocol based cars... 43 02 01 02 01 13 is the right message.
    43 is a mode request, which means its asking for a DTC request.
    02 means there are two trouble codes
    01 02 means P0102
    01 13 means P0113
    Hope this helps!
  1. Replies: 41
    Last Post: 09-20-2010, 09:58 PM
  2. Can't Clear Trouble Codes on VPW protocol?
    By split63 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-30-2010, 01:35 PM
  3. Codes?
    By avz in forum Car Audio
    Last Post: 03-04-2009, 09:00 AM
  4. OBD-Codes.com
    By Swanny in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-09-2009, 03:34 AM
  5. kenwood codes
    By bigjez in forum LCD/Display
    Last Post: 09-10-2004, 07:24 AM
Tags for this Thread
