Results 1 to 10 of 12
Thread: Does anyone know what is OBD II protocol for 2010's hondas
    Newbie Saran_yim's Avatar
    Oct 2010
    Thailand
    Question Does anyone know what is OBD II protocol for 2010's hondas
    I've search in internet and found that Honda use CAN with 29 bit ID
    I try to send 0x18DA11F1 02 01 00 55 55 55 55 55 but have no answer from ECU
    But when I set my CAN MCU to just monitor I see some communication on the bus which has 11 bit ID mode
    and I found that on the OBD connector has cable go to pin number 7 as show in spec it is ISO K line
    I use digital multi-meter measure on that pin and got 7.x volt but it should be 12 volt
    So I try on ISO with 5 baud and FAST init and not success to communicate with ECU
    Any suggestion?
    Oct 2008
    Required by law (both OBD2 in the USA and EOBD in Europe) it must be can (from 2008 on).
    So, what happens if you try 11-bit can?
    Oct 2010
    Thailand
    I try 0x7Ex for 11 bit can there are also no answer any idea?
    I also try 250k and 500k baud rate but still no success
    Oct 2008
    What happens if you try the functional address (0x7DF) in stead of the physical address?
    I just saw you live in Thailand. I don't know if your country requires OBD2 (or JOBD) to be present on the car.
    When not, it is entirely possible that the car will not support OBD2.
    Oct 2010
    Thailand
    I did not try 0x7DF yet but I will try that.
    We don't have regulation to force to car manufacture to strick to any standard but for sure that since 2000+ all new car equipped with OBDII
    I will comeback with the result.
    May 2011
    If you have the chance, try an ELM-327 scantool. It will automatically detect the protocol, and you don't have to be concerned with the details at the vehicle end. You simply send standard OBD2 commands (mode1,2,3, etc) via a comm port on a PC or any RS-232 device. I got a generic ELM327 usb scantool from Ebay for about $20. It works on Honda 2007 (ISO) and Honda 2010 (CAN). Hope this helps.
    Oct 2010
    Thailand
    Smile
    Hi, I just bougth ELM327 for testing and it working perfect and I found that it is a bug from ST micro who's produce MCU that I use in this project, Thank you for help
    Low Bitrate sinclairvital's Avatar
    Jun 2005
    Functional address needed
    Quote Originally Posted by Saran_yim View Post
    Any suggestion?
    Should have used 0x18 DB 11 F1 02 01 00 55 55 55 55 55
    Sep 2012
    Any suggestion?
    Hi , if your vehicle supports 29bit CAN eobd , you must send 0x18DB33F1 as CAN address (try both baudrates 250K , 500K)
    Also try to to send 0x18DB33F1 02 01 00 00 00 00 00 00 (fill the bytes with 00 , not with 55)
    You will receive a reply from :
    0x18DAF110 Engine
    AND
    0x18DAF118 Transmission if the car is A/T
    Feb 2013
    Quote Originally Posted by Hercules View Post
    0x18DAF110 Engine
    AND
    Hi, Hercules
    I have tested our OBDII equipment on Honda Insight hybrid 2012 (CAN 29/500) and got non-standard address in answer: 0x18DAF10e (Engine???), 0x18DAF103 and 0x18DAF104.
    As the result my FW that wait for 0x18DAF110,0x18DAF118 (Transmission) and 0x18DAF128 (ABS??) does not work.
    Do you now why Insight answers have othe address? Where can I find the list of possible addresses for different car manufacturers.
    Thanks in advance
    Alex
  1. OBD II / CAN protocol
    By guy7373 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-28-2009, 04:44 AM
  2. Which protocol is this?
    By aghazi in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-16-2006, 10:34 AM
  3. HOndas
    By azoodica in forum Newbie
    Last Post: 06-22-2005, 07:45 AM
  4. Rice-Hondas worthless?
    By Aaron Cake in forum Off Topic
    Last Post: 07-03-2002, 12:48 PM
