Results 1 to 4 of 4
Thread: How to replay a command back to a module on the bus
    May 2011
    Let's say I'm logging and I narrow down an interesting command that does something useful like lock the doors or lower the antenna or whatever. With filtering I narrow it down to something like so:
    2CD 0A 44 5D 60 00
    How do I replay or replicate that to make it happen "on demand"? Do I need to set the receive address (RA) or the CAN Receive Address (CRA) or how is actually done? I'm sure this is child's play once you know how, but since I don't know how... any example would be great.
    Thanks!
    Dave
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Dave,
    The following assumes you are using OBDLink, and the protocol is CAN 500 kbps 11-bit:
    1. Change the protocol to "USER1 CAN" (ATSP B). You can't use ATSP 6 because you don't want the PCI byte to be sent automatically.
    2. Set up the baud rate for Protocol B:
    ATPP 2D SV 01
    ATPP 2D ON
    ATZ
    3. Set up the header, in this case ATSH 2CD.
    4. Enter the data bytes to send: 0A 44 5D 60 00.
    Vitaliy
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    May 2011
    Quote Originally Posted by Vitaliy View Post
    Dave,
    ATPP 2D SV 01
    ATPP 2D ON
    ATZ
    Vitaliy
    Thanks! I would have guess ATWS instead of ATZ, as I thought ATZ was a full reset. But the ATPP values persist though an ATZ reset?
    Dec 2006
    Phoenix, AZ
    Quote Originally Posted by DAVEPL1968 View Post
    ATWS would work, too. ATPP (programmable parameters) value are saved in non-volatile memory.
    Vitaliy
  1. "BACK" command and Directory Listing
    By All4Sky in forum RR Skins
    Last Post: 10-17-2011, 08:01 AM
  2. Voice command for scripted module?
    By gravy in forum DigitalMods (Scripts / API)
    Last Post: 09-30-2007, 12:08 PM
  3. FS: SIRIUS Starmate Replay Brand New
    By ckny in forum Classified Archive
    Last Post: 10-27-2006, 12:09 PM
  4. Replies: 15
    Last Post: 08-03-2006, 07:02 PM
  5. Install of Sirius Replay?
    By LilSnoop40 in forum General Hardware Discussion
    Last Post: 12-05-2005, 03:33 PM
