Results 1 to 2 of 2
Thread: Time between bytes in ISO 9141-2 and KWP2000
    Jan 2011
    Hi!
    I am building an ECU simulator. How much time should pass between byte and byte when the ECU transmits a message?
    For example, if the request is : 0x68 0x6A 0xF1 0x01 0x0D (pid =0x0D)
    the ECU´s response is: 0x48 0x6B 0x10 0x01 0x0D 0x12
    For example, between 0x48 and 0x6B. How much time is there?
    Thanks!!
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    The bulk of your questions can be answered by reading the appropriate standards. In this case, it would be the ISO 9141-2. There are dozens of timing parameters that you need to know to build an OBD simulator, do you seriously intend to create a post and ask for each one of them? Yes, the spec is not free (it's ~$30, IIRC), but you need it to do your project. Save your lunch money, buy the document, and stop wasting bandwidth with RTFM-type questions.
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    — Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
  1. Bytes transmission of CAN protocol (iso 15765)
    By proyectanteATE in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-05-2012, 06:49 AM
  2. ELM 327 , ” headers of 4 bytes”,
    By OPMOTOR in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-24-2012, 03:25 PM
  3. Key bytes and electrical level in ISO14230-4 protocol
    Last Post: 02-17-2011, 06:18 PM
  4. ELM327 Request more than 6 Bytes.
    By Supertrade in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-16-2011, 09:39 AM
  5. Will ISO 9141-2 work with a car with ISO 9141?
    By tdb30_ in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-01-2008, 08:17 PM
