Results 1 to 3 of 3
Thread: How does OBDII protocol works?
    May 2011
    Hi,
    I'm trying to understand how the OBDII protocol works.
    If I connect an OBDII dongle, how does it collects the data?
    Does it only listen on the bus and collect the data as it passes? or does it send a data-request and gets an answer?
    What else can I send to the engines computer other than MIL light reset? anyone knows a list or something?
    Thanks!
    Oct 2008
    You need a combination of Hardware and Software. The hardware is a cable between the diagnostic connector and the device that runs the software for reading codes and/or data. It doesn't matter whether you use a PC-program or a dedicated scanner.
    OBDII provides ways for reading/clearing codes and reading all kinds of data - live data, test results and ecu information.
    The way it works is the scanner will ask a question and the OBDII legislated ecu's (engine and automatic gearbox) will answer.
    Have a look here: http://www.mp3car.com/engine-managem...is-obd-ii.html
    and here: http://en.wikipedia.org/wiki/OBD-II_PIDs
    May 2011
    Thanks alot!
  1. Audi A4 OBDII Protocol?
    By NZHawk in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-16-2010, 09:30 PM
  2. Replies: 13
    Last Post: 04-07-2010, 02:16 PM
  3. OBD II / CAN protocol
    By guy7373 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-28-2009, 04:44 AM
  4. Which protocol is this?
    By aghazi in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-16-2006, 10:34 AM
  5. OBD-II IOS protocol (BMW)
    By sstainba in forum Coders Corner
    Last Post: 03-16-2006, 07:00 PM
Tags for this Thread
