Results 1 to 3 of 3
Thread: Mode 0x06. Request On-Board Monitoring Test Results for Specific Monitored Systems
    Jan 2011
    Hi everybody!
    When my ECU receives a mode 6 request in ISO 14230-4, for example: Header bytes + 0x06 0x02 + checksum
    My ECU replies with: Header bytes + 0x46 0x02 0x16 0x00 0x32 0x00 0x20 + checksum, where:
    0x02: TID Lean to rich sensor threshold voltage
    0x16: test limit type
    0x00 0x32: test value
    0x00 0x20: maximum test limit.
    My question is: How does the scan tool interpret the test value or test limit?
    My idea is: 0x00 0x32 = 50 decimal = 50 V but I think this is wrong.
    I hope you could help me!!
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    You need to use the scaling for that particular Test ID. In this particular case, if the manufacturer obeyed J1979 recommendations, it is 0.005V/bit.
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    Jan 2011
    Thanks Vitaliy!! Then in my example the scan tool interprets 50*0.005 = 0.25 V?
  1. Relationship Mode 1 and Mode 06 (Request On-Board Monitoring Test Results) in KWP200
    By proyectanteATE in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-23-2011, 04:56 PM
  2. CAN Mode 0x06 Multi-line messages
    Last Post: 02-09-2011, 02:28 PM
  3. Tire pressure monitoring systems
    By jlnike in forum Newbie
    Last Post: 09-24-2010, 12:29 PM
  4. Replies: 10
    Last Post: 09-22-2010, 10:06 PM
  5. monitoring systems?
    By crzystng in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-22-2006, 10:05 AM
