Results 1 to 5 of 5
Thread: Recommended software for BMW
    May 2011
    Salem, OR
    I'm installing a carputer in my E39 and want to know what all I need to get live data and pull codes on the go. Any info is much appreciated.
    Josh
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Permanent install? Do you need USB or Bluetooth?
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    May 2011
    Salem, OR
    Quote Originally Posted by Vitaliy View Post
    I'd like it to be removable, but can be permanent if need be. I'd prefer USB
    Dec 2006
    Phoenix, AZ
    Quote Originally Posted by Jesus Freak View Post
    "Permanent" in this case means you intend to leave the interface plugged in (as opposed to "connect, scan, unplug").
    OBDLink USB or OBDLink SX are both good choices. Depending on the location of the DLC, you may want to get OBDLink with a right angle connector, to keep it out of the footwell.
    You would also need to enable PowerSave so it doesn't drain your battery.
    Vitaliy
    May 2011
    Salem, OR
    Vitaliy
    Does OBDLink work with BMW's? From my reading I've found most generic OBDll scanners/software don't work for BMW's. I just want to be 100% sure before I go spending $100+ on software that won't work for me, because I can't return it. Lol
  1. Recommended Mazda OBDII Software
    By Fireman27 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-14-2008, 04:53 PM
  2. Recommended gauge
    By DracoPCGuy in forum Newbie
    Last Post: 03-31-2008, 11:42 PM
  3. Recommended S/W for Jeep
    By asp_777 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-20-2007, 03:20 PM
  4. Recommended backup software?
    By muldrick in forum Software & Software Development
    Last Post: 11-14-2005, 10:43 AM
  5. REcommended Cameras?
    By ukchris in forum General Hardware Discussion
    Last Post: 09-30-2005, 07:28 PM
