Results 1 to 9 of 9
Thread: Calculate LPK from OBD2
    Jun 2011
    Hi to all.
    I'm trying to create correct formula for calculating average litres per 100 kilometers.
    I've read this topic and parsed formula for getting MAF, KPL (kilometers per liters), LPK (liters per kilometers moment) and LPS (liters per second). But I'm still unable to create formula for average LP100K.
    I'm hard to create formula because I don't understand how to adjust average LP100K when I'm standing in traffic.
    Thanks beforehand for all yours help
    Dec 2007
    Sydney Australia
    If you know kilometers/litre then it is easy to get litres/kilometer and if you then multiply this by the kilometers travelled you will know the litres used.
    Then I expect it is as easy as adding the litres/sec at each second standing still in traffic to the number of litres used and redivide by the number of kilometers/100 to get your average litres/100km.
    Does this make sense ?
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
    Jun 2011
    Yeah, it does. But litres/kilometer changes every second 1st second it can be 0,067 liter/kilometer and next second it can be 0,357 liter/kilometer
    But, the main idea I received, today I'll work on this data and try to create some formulas and test them. So, today evening I'll write the result of my work
    Jun 2011
    I found another solution.
    I just calculate sum of all LPS and devided them by distance that I travelled and multiply it by 100 That's shows me the average litres/100km. Now this formula is in testing. I hope it will work as I need...
    Raw Wave
    Nov 2009
    Readings like that almost always need filtering.
    You need to decide what "resolution" you want, and be aware that the only accurate figure is that over the entire period (ie, fuel & distance for 3 readings, 3 seconds, 3 hours, the whole trip, since trip start etc).
    Most in-car economy meters have the "total" since trip start or tank refill, get a "moving" average (eg, last 500k etc) as well as the "instantaneous" reading - which is usually an average when sub-second samples are involved - eg, 10 MAF readings per second but displayed only every 1 or 3 seconds).
    Analogs simply use an RC filter, and produce accurate tracking.
    Digital require copious sampling and filtering algorithms to do the same, but are perfect for total displays (ie,long term, not real time; but that's the advantage on analog computing isn't it?)
    Dec 2007
    Sydney Australia
    LPS/100km is missing a time constant (sec) in the equation to mean anything. So what you have is Litres/sec/100km
    Like oldspark says, you need to define what period of time you want your readings to represent.
    If it is per second then your figures are correct, but if it is a minute then you need to add 60 readings together and divide the sum by 60. If it is an hour then you need to add 3600 readings together and divide by 3600...
    There is also the running average but this is still time period dependant, needing a running sum of 60 or 3600 samples.
    Raw Wave
    Nov 2009
    Though litres per (100)km & km/L etc require no time constants.
    And L/s/km etc makes no sense... (other than "for the last x-km, you got y L/sec" etc).
    To paraphrase the issue I was getting at - instantaneous "digital" readings such as AFMs, injector volumes, etc, vary wildly with compared to the actual average over a few sample periods.
    Usually injector pulses are used to measure quantity - they should be more accurate than AFM, MAPs etc (even without pintle opening/closing compensation).
    Jun 2011
    I'll try to explain my solution.
    I'm using sum of ALL LPS + Trip (a whole trip).
    For now I'm receiving correct values of LPK average. I just calc sum of LPS and devide it by trip. time of measure is 1 sec. So, i can remove it from my formula.
    Raw Wave
    Nov 2009
    Than you have to multiply out LPS by S to get L.
    Then divide by total distance.
    Not as accurate as a raw L count, but if that's all there is.....
    (That's why I'd try to tap the L counter source, but that could be from an injector algorithm.)
  1. Could this be a method to calculate diesel mpg?
    By sonicmule in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-02-2011, 08:07 PM
  2. how to calculate the mileage of isuzu nhr 55e
    By sanxing_jomar in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-04-2010, 12:24 AM
  3. How should I calculate fuel range
    Last Post: 07-23-2009, 08:42 AM
  4. How do i calculate the amp wattage i need?
    By Blop in forum Car Audio
    Last Post: 05-23-2005, 11:47 AM
  5. Calculate LED Watts
    By bambooracer in forum Off Topic
    Last Post: 06-20-2004, 04:40 AM
