Results 1 to 3 of 3
Thread: Need Help Soon with OBD and willing to pay
    Apr 2011
    I am in the process of swapping an LS3 in an E46 M3, I am not going to use the stock cluster as it is way to much work. I am going to be using after market fuel, speed, tach, temp gauges now in the middle of this I would like a 2.5" vertical touch screen if possible in between the speed and tach. A super fast booting computer low storage that i will only use for car stuff and display only on the 2.5" screen. I have a dynavin unit for my audio needs so no need for that.
    I would like this to remain a black screen once booted up aside from reading the turn signals, high beams, check engine light, oil level, oil pressure. Basically have warning lights just like a regular car. The reason I want it touch screen if possible is say the check engine light comes on and I touch where it is at I would like it to display what is wrong such as the code thrown and a description already pre loaded. The illuminated display has to look extremely professional as I wouldn't have it any other way. If anyone is interested in writing the software and designing a semi cheap computer with os email me. I should be looking at getting this done very soon.
    I may want other things incorporated but havent totally thought them through.
    Personal email nelsonsethw@gmail.com
    Oct 2008
    For any engine logging or displaying (data or codes) check with the manufacturer of the after market ecu for possibilities.
    They sometimes vary.
    Aug 2011
    Jesus man, that sounds like a serious project either way. Please please post pics here if you get this set up. Sounds like it would be sick if you did.
