ECU does not privede ack ? Did you mean "ACK" = ack bit in can packet ?
I am not expert in CAN, but what I know, every device on the CAN bus provide ACK for every packets. Even if it was not packet for this ecu. So if you will send on right speed, timequanta, ... you should get ACK always (when there is even one another device on the bus).
LinkBack URL
About LinkBacks
