Results 1 to 10 of 11
Thread: ODB Renault Clio Mk2
    Jun 2011
    Dublin, Ireland
    Just wondering if anyone has had any success using any diagnostic tools with a Renault Clio mk2. I bought 2 usb scanners and have tried lots of software but it just won't communicate. (Note that they were cheap ones from ebay)
    I don't want to spend anymore money unless I'm pretty sure it'll work.
    My car is a 2000 reg.
    Oct 2008
    2000 model is not required to comply with the EOBD rules if it was also sold in 1999.
    Petrol or diesel engine?
    Jun 2011
    Dublin, Ireland
    It's a 1.2 petrol.
    Oct 2008
    How many Oxygen sensors are there on the car?
    Is there an Oxygen sensor after the catalyst?
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    usually there is a before and after the converter inline engines and if v-6/8/10 engine it would have 4, 2 on each side SNO
    Jun 2011
    Dublin, Ireland
    As far as I know it just has the one.. I could be wrong.
    Oct 2008
    With only 1 Oxygen sensor it's definitely NOT compliant with anything.
    You need a factory/dealer scanner or something similar to read the codes and data.
    Jun 2011
    Dublin, Ireland
    Ah disaster. :-( Thanks for the help.
    Sep 2011
    renault diag
    Hi!
    You can read your car with DDT2000 software by renault with simpe k-line adapter. You only need to know some french to decode DTC.
    Newbie Phreak Show's Avatar
    May 2006
    Germany, Bavaria, Augsburg
    MK2 means second series of Clio, I guess. That means you should have a D7F engine with 1149cm³ and like 60hp.
    This Clio is quite special, it's got a Siemens Sirius32 ECU. And only this ECU supports OBD. I used to drive that car (germany), so I know about the facts.
  1. help with ma new renault clio plz
    By deris99 in forum General Hardware Discussion
    Last Post: 02-20-2011, 07:36 PM
  2. Renault Clio Car PC!
    By TheBestJack in forum Worklogs
    Last Post: 01-13-2011, 07:12 PM
  3. Renault Clio - Car PC
    By TheBestJack in forum Newbie - Proposed setup
    Last Post: 01-05-2011, 12:19 PM
  4. Renault Clio 2000
    By Stooboy in forum Show off your project
    Last Post: 09-26-2005, 05:29 PM
  5. Renault Clio Help!
    By nathan2oo3 in forum Newbie
    Last Post: 08-12-2005, 08:39 AM
