I do not accept private messages via this forum. If you need to contact me privately, send me an email (see my signature).
Printable View
Sneak peek: STN1170 datasheet.
Yes I would like to know how you are looking as well? Or are you just looking at what comes across, pushing a button and see what happens?
I would like to communicate with my truck and play with some things.
In my case I intend to remove some of the controls in my truck and replace them with controls from an ARM based computer hidden in my dash connected to a touch screen. This also allows controls to be done easily for security as well.
I have a 2003 GM truck I want to play with...
I also have a laptop I will use to chat with it until I have this itty bitty computer running with it.
(Using a Freescale i.MX53 QSB as a development system. This is a 1ghz ARM system that runs WinCE7, Android, or Linux. May move to a quad 1.2ghz i.MX6 once I have some of this figured out but heck, $150 for a full blown computer I can't beat for "playing around with".)
The GM truck is likely using VPW for control, so any OBDLink or STN11xx would work with it. In other words, it doesn't have to be MX or STN1170.
Disclaimer: you're basically on your own when it comes to reverse engineering. STN11xx gets you on the bus, but it's up to you to figure out what the messages mean.
Vitaliy
Thank you, this is what I expected, when I originally started looking into this I was afraid I would have to tie directly into the High speed and Low speed buses and get into proprietary networking but it sounds like everything is accessible through the ODBII connector and so I should be able to access all of the modules that are on either of the buses?
There is information available out there for me to be able to reverse engineer most everything I need although I will hopefully be looking for someone else who has been there done that. The main thing for me at this point was to connect to it.
I have built another one:
http://i48.tinypic.com/2u542uh.jpg
http://i47.tinypic.com/2ugcdmo.jpg
http://i49.tinypic.com/vebtb5.jpg
Regards
