Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: ELM329 custom USB interface
    Newbie reinoso's Avatar
    Nov 2010
    Spain
    Hello,
    I have designed a custom PCB with ELM329. It has two CAN transceivers, microchip MPC2551 for HSCAN and Melexis TH8056 for SWCAN. This board is specially designed for GMLAN cars.
    You can switch between HSCAN and SWCAN sending the AT C0/C1 command.
    I can't wait to start sending AT commands on my SAAB 93 MY2005
    In the picture MCP2551 was not soldered yet. USB to UART IC is FT232BL.
    Hope you like.
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Very awesome. Sounds like you've made it easy to switch between hscan and swcan. Does it automatically know the protocol to use for these or do you have to use the ELM AT commands to set the protocol/baud/etc?
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
    Nov 2010
    Spain
    you have to set the protocol and baud rate manually, as you would do with ELM327 based devices.
    This board only has a hardware switch that routes CANTX and CANRX to the corresponding transceiver. This hardware switch is controlled using AT C0/C1 command.
    AT C0 = MCP2551 (HSCAN, default)
    AT C1 = TH8056 (SWCAN)
    Aug 2009
    Melbourne, Australia
    I guess the next big question on the lips of many is will you be producing these items for purchase or can we get a BOM and the PCB file.
    thanks
    Michael
    Nov 2010
    Spain
    I had not planned to sell this board, but if many people is interested, I'd consider to make a few.
    Well, today I spent a few hours doing some sniffing. I identified the code for activating ligths, wipers, etc.
    I forwarded the data packet and all work OK, but only for a while (ie. wipers are activated only for a second). It is normal because the original ECU is also sending the "OFF" packet periodically.
    My question is, if I want to make my own circuit to turn the lights on without using the original button, Do I have to always be sending the "ON" packet faster than original ECU? I don't like this "bus fight", is there any way to avoid this situation?
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    I don't think you can avoid the fight. You are essentially spoofing the message from the module that controls the wipers. You'll probably have to listen for the "off" from the original module and immediately issue an "On".
    I don't understand how this hardware differs from say a obdpro scantool that's modified to work on the swcan bus. Can you illustrate the difference?
    Nov 2010
    Spain
    Thanks for the answer tripzero.
    Doors lock work in that way too??? Or there is only a packet for ON and other for OFF, and no periodically "reminders"
    Nov 2010
    Spain
    Quote Originally Posted by tripzero View Post
    It is simple, it has a SWCAN transceiver attached to ELM device: Melexis TH8056.
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Do you use a custom pinout for your OBD to DB9 cable?
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    Nov 2010
    Spain
    Quote Originally Posted by Vitaliy View Post
    Yes.
  1. Custom USB tyre pressure monitoring interface
    By Robby BMW in forum Portal Media Car PC Gadgets and Accessories
    Last Post: 01-10-2016, 10:28 AM
  2. Custom USB Parking Sensor interface (formally PDC-USB)
    By Robby BMW in forum Hardware Development
    Last Post: 01-15-2015, 12:51 AM
  3. Replies: 14
    Last Post: 10-11-2010, 03:44 PM
  4. Replies: 2
    Last Post: 12-19-2005, 06:47 AM
