Results 1 to 8 of 8
Thread: Dual-speed CAN
    DFR
    DFR is offline
    Nov 2011
    Hanover, NH
    Dual-speed CAN
    Hey guys,
    I'm doing a telemetry project on my car, trying to collect and log a bunch of data using a carpc. I've got a kind of a unique situation on my hands, though: my car has 2 CAN busses, running at different speeds. One is car-wide, moves a lot of temperature and acceleration data, and runs at 500kbps. The other is the datastream from the ECU, and it runs at 125kbps.
    Does anyone know if something like a ValueCAN, that has two inputs, would handle the dual speeds okay?
    Thanks!
    Newbie reinoso's Avatar
    Nov 2010
    Spain
    hello,
    My interface has two CAN inputs , but one is SWCAN.
    Do you need to process both at the same time?
    DFR
    DFR is offline
    Nov 2011
    Hanover, NH
    Yes, I do need to process concurrently
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Two ValueCANs?
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    DFR
    DFR is offline
    Nov 2011
    Hanover, NH
    Two ValueCANs would strain my budget. Is it not possible to use the two channels on the ValueCAN at different speeds? It seems like it should be...
    Dec 2006
    Phoenix, AZ
    As far as I know, you can only monitor one channel at a time. Two OBDLink SXs would run you $100:
    http://store.mp3car.com/OBDLink_SX_2..._p/com-145.htm
    Jul 2005
    Michigan
    ValueCAN can do two CANs.. at the same time.. there are two versions a 1x and 2x the 2x is called the ValueCAN3 (don't ask).
    Just go to intrepidcs.com...
    Hack your car's CAN BUS at www.canbushack.com
    Jul 2011
    I am rethinking my approach... so wondering if there is a wireless (WiFi, BT) version of OBDLink that would withstand full utilization of 500k bus for let's say 2 hours without "Buffer full" incidents or even worse with quiet loss of frames.
  1. Replies: 4
    Last Post: 10-28-2010, 09:24 AM
  2. Speed Limit / Speed Zone Plugin RELEASED
    By ThunderStick in forum RR Plugins
    Last Post: 12-20-2008, 01:03 AM
  3. Replies: 2
    Last Post: 08-31-2005, 06:01 PM
  4. Hi Speed USB drive plugged into Lo Speed USB port
    By masch in forum General Hardware Discussion
    Last Post: 03-12-2005, 01:49 PM
  5. Replies: 11
    Last Post: 04-12-2004, 05:10 AM
