Results 1 to 9 of 9
Thread: Which diagnostic interface di I have?
    Nov 2011
    Question Which diagnostic interface di I have?
    Evening all. New poster, long-time lurker.
    I've got a decent car-pc built as far as entertainment and basic travel utilities go, but I'm looking to expand into on-board diagnostics.
    The trouble is, my vehicle is a custom built 1994 Ford E-250 (former ambulance). And I can't find out what interface it uses for diagnostics!
    From poking around, I've found BOTH an OBD (hopefully OBD=II?) port, and an EEC-IV port. But as of yet I don't know which one works. Is there a guaranteed (but cheap) way to find out which one I should be using?
    And if it's the EEC-IV port, is there a cable to connect it to my car-pc, and software to utilize it?
    Thanks in advance!
    VENDOR - ScanTool Vitaliy's Avatar
    Dec 2006
    Phoenix, AZ
    Buy a cheap scan tool.
    I would be very surprised if the vehicle supports OBD-II.
    OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
    Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
    You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    I would guess it will be EEC-IV
    Oct 2008
    Find somebody with a suitable scanner and have them checkout which interface to use.
    Snapon has the name that most of these old cars were covered - at least in the old domestic software.
    Have you looked for the engine ecu? What numbers are on the sticker(s)?
    Nov 2011
    I've been looking for it, and have yet to find it. I know the interfaces are both under the kick panels up front (OBD-II on the driver's side, EEC-IV on the passenger).
    Of course, it took me a week to find the oil filter too (under the doghouse inside the cab, instead of where it should be).
    Any idea of where to look?
    Oct 2008
    No, I am no expert on these kind of cars, so don't know where the ecu is. Even experts may hesitate to answer, because it's custom build.
    Your OBD2 connector: what pins are present? That might give a clue what protocol is used.
    Trick I often use is to start at the engine and follow the wiring from the injectors. Where is that going to?
    May 2009
    Do you have this type of conn. in a car ?
    http://www.allfordmustangs.com/forum...opic2471-1.gif
    If you have data+/data- pins there, you should have EEC IV with live data capability.
    Tomas
    Nov 2011
    I'll check that later today. I DO know that there's wiring running from both connectors up under the dash and into the firewall. But then again, there's wiring running everywhere in this thing. When they decommissioned it as an ambulance, they weren't exactly gentle.
    Nov 2011
    Sorry I've not gotten back to this yet, but catching the flu has knocked me right out. Hoping to get a chance to check it today, if it stops raining.
  1. ELM327 VS. OBD Diagnostic Interface..need advice!
    By qewani in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-29-2009, 05:43 PM
  2. Diagnostic help please
    By blackcobra487 in forum General Hardware Discussion
    Last Post: 12-08-2008, 02:49 PM
  3. Gps Diagnostic
    By 4u2n in forum GPS
    Last Post: 09-06-2007, 03:01 PM
  4. Where to find a Diagnostic MOST Interface?
    By Viscouse in forum Hardware Development
    Last Post: 08-24-2005, 12:14 PM
  5. FS: OBDII diagnostic interface
    By deskcom in forum Classified Archive
    Last Post: 12-10-2004, 12:24 AM
