Results 1 to 3 of 3
Thread: Trouble requesting PIDs from EDC16U1 (CAN11bit)
    Dec 2011
    Hello all,
    From search to search i`ve come across mp3car.com , hope you can help me and i can help you.
    I`ve made 2 CAN nodes that pass a series of data from one to another. The CAN nodes consist of MCP2515+MCP2551+Atmega16L(1st node)/Arduino(Atmega328,2nd node). The can works ok i send and receive the message ok with no errors.
    After some time i`ve added an ECU (EDC16U1 (just power and CAN wires connected) from an VW Touareg).
    I use node 1 to request the coolant temperature with the following message:
    Lenght: 8
    RTR: 0
    Data: 0x02 0x01 0x05 0x00 0x00 0x00 0x00 0x00
    But i get no replay from the ECU.
    Now my question is , i`m doing something wrong or the ecu is supposed to send this information only over the K-line?
    Thanks !!
    I have attached 2 txt`s , One only with the ecu sending to the nodes , and the other one the ecu and node 1 making the above request but no answer.
    Attached Files Attached Files
    Oct 2008
    I all depends on the model-year of the car (ecu) and in which part of the world you live.
    Can is not mandated by EOBD or OBD2 until 2008, so the old trusted k-line could still be used.
    If you live somewhere in the world where there's no standard required, then anything is possible.
    Dec 2011
    Thank you for the replay p2psmurf.
    Well ECU is from the first generation of Touareg , year 2005 , 2.5L engine. Will search to see if the ECU can be diagnosed by can.
    Is my can message to request the PID correct ? I am unsure about the RTR bit, i saw some examples on google and they all where using RTR recessive , tryied dominant too but no change.....
  1. Requesting help with CarPC wiring.
    By Sam White in forum Newbie
    Last Post: 10-09-2011, 04:57 AM
  2. Standardized PIDs versus Manufacturer Specific PIDs??
    By split63 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-04-2009, 02:54 AM
  3. LQ9D161 + parts, requesting help
    By LycaonX in forum LCD/Display
    Last Post: 06-11-2007, 06:47 AM
  4. Requesting custom variables out of RR
    By lostreception in forum Road Runner
    Last Post: 08-26-2006, 11:36 PM
  5. Requesting 1.5 screenshot from David :)
    By justintime in forum Centrafuse
    Last Post: 10-14-2005, 06:20 PM
