Does your OBD port have CAN pins (6 & 14)?
I'm curious, why isn't coolant temperature good enough for your purposes?
Vitaliy
Printable View
Yes, the OBD port have the pins 6 and 14.
I need the oil temperatur because my car doesnt display it.
Is it possible to read out measuring block groups wit the OBDLink MX?
Monitoring the CAN bus will be wonderfull, how can i do it?
I saw thats i was connected to my car over the ISO 9141-2 (5 baud init, 10.4 Kbaud) protocoll, can i monitor it too?
What about boost pressure in a 2004 VW?
I've been testing out the obdlink mx with my new project (automotive message broker) and am noticing a speed difference between the mx and the OBDLink S. Using ECUSim with ISO 15765 I get about 20pids/second with the MX. With the OBDLink S I get about 30pids/second. I've tested using the recommended logitech bt dongle and some others and get the same results.
Is it typical for the MX to underperform the S when doing OBD-II?
I should note that there may be serious noise issues. There are at least 6-12 bluetooth devices in the area.
