Yes, the OBD port have the pins 6 and 14.
I need the oil temperatur because my car doesnt display it.
Is it possible to read out measuring block groups wit the OBDLink MX?
OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
Monitoring the CAN bus will be wonderfull, how can i do it?
I saw thats i was connected to my car over the ISO 9141-2 (5 baud init, 10.4 Kbaud) protocoll, can i monitor it too?
What about boost pressure in a 2004 VW?
you can monitor with the ATMA command. Find out what that means by reading the protocol documents for the obdlink products. Or read the documents from your software vendor and see if your software has a monitor mode.
Former author of LinuxICE, nghost.
Current author of nobdy.
sometimes those codes are available over OBD-II (Boost pressure control is one of the standard ones IIRC). Otherwise, you are looking at figuring out if boost pressure is available over the CAN bus and what the message looks like.
I've been testing out the obdlink mx with my new project (automotive message broker) and am noticing a speed difference between the mx and the OBDLink S. Using ECUSim with ISO 15765 I get about 20pids/second with the MX. With the OBDLink S I get about 30pids/second. I've tested using the recommended logitech bt dongle and some others and get the same results.
Is it typical for the MX to underperform the S when doing OBD-II?
I should note that there may be serious noise issues. There are at least 6-12 bluetooth devices in the area.
KWP2000 should be accessible with most standard OBD hardware. For KW1281 or TP2.0 (over CAN bus) you need something like the OBDKey or VCDS.
