Cant wait to try it out and compare to my ancient USB OBD module.
[top]The World's Smallest & Fastest OBD Adapter Provides Access to Single Wire and Medium Speed CAN networks
Engineered to accelerate performance over the Bluetooth link, OBDLink MX is up to 5x faster than the closest competitor. The world's smallest OBD adapter provides access to SW CAN & MS CAN networks in addition to legislated OBDII. Thanks to the unique BatterySaver™ technology you can rest assured that, unlike other OBD adapters, MX won't drain your battery if you leave it plugged in.
- Up to 5x faster than the closest competitor – MX accelerates Android apps by up to 25% and PC software by up to 400%. Experience faster screen updates and more graph points.
- Supports SW CAN & MS CAN protocols – MX is the only scan tool in its class that can access these proprietary GM & Ford networks in addition to the 5 standard OBDII protocols.
- World’s smallest scan tool – At just under 2” long, OBDLink won’t obstruct driver legroom.
- Hack-Proof – Cutting-edge security scheme virtually eliminates the risk of unauthorized access.
- BatterySaver Technology – MX’s innovative sleep function lets you leave it plugged in without danger of draining your car’s battery.
- Read & Clear Check Engine light – Check diagnostic codes yourself and make informed repair decisions.
- Works on PC’s, Smart Phones, and Tablets – Turn your laptop, netbook, Android, or Symbian device into a sophisticated diagnostics tool and performance monitor. Note: Not compatible with Apple products.
- Works on a wider range of vehicles – OBDLink’s advanced algorithm enables MX to connect to more OBDII-compliant makes & models than any other scan tool.
- Free diagnostics software – Includes ScanTool.net’s exclusive OBDwiz license for Windows (a $39.95 value)
- Peace of Mind – Covered by our 3-year warranty & 90-day money-back guarantee.
- Superior Compatibility – works with more 3rd party apps & software than any other adapter.
— OBDLink MX: world's smallest, fastest, most advanced OBD/Bluetooth adapter with SW and MS CAN support. Read the review to learn more.
— Need to look up a diagnostic trouble code? Try the most up-to-date, free DTCsearch.com!
You cannot send me a private message using this forum. Use my email instead: vitaliy[@]scantool.net.
Live mp3Car Facebook Chat
Will there be a wired version? How's bluetooth performance? Does it support SW CAN hi-voltage wakeup?
Also, is the SW CAN implemented like the normal ELM-style? ie ATMA to read? It'd be nice to be able to write without having to interrupt reading. You may miss critical messages and software ends up in a bad state. Sadly the alternative to today's scantool seems to be 2 scantools. One for dedicated reading and one for dedicated writing. This device doesn't happen to solve that does it?
It'd be cool to put the scantool in a special mode (ie STMA), where reading would resume indefinitely without having to spam atma everytime you try to write something... Maybe that can be solved in firmware?
Excited,
-tripzero
Former author of LinuxICE, nghost.
Current author of nobdy.
Device that looks totally inspired by this.Vitaliy?
Perhaps.
Excellent. We were pushing 130 PIDs/sec on CAN. The catch is, it seems to depend A LOT on the USB/Bluetooth dongle. 130 was with the fastest dongle. Others were as bad as 20 PIDs/sec.How's bluetooth performance?
Naturally!Does it support SW CAN hi-voltage wakeup?
No, sorry.Also, is the SW CAN implemented like the normal ELM-style? ie ATMA to read? It'd be nice to be able to write without having to interrupt reading. You may miss critical messages and software ends up in a bad state. Sadly the alternative to today's scantool seems to be 2 scantools. One for dedicated reading and one for dedicated writing. This device doesn't happen to solve that does it?Asynchronous send/receive is on the drawing board.
Yes, it certainly can be. Just a matter of time.It'd be cool to put the scantool in a special mode (ie STMA), where reading would resume indefinitely without having to spam atma everytime you try to write something... Maybe that can be solved in firmware?
Vitaliy
awesome. Sign me up!
I'll be reviewing this unit very soon![]()
What does the STCSWM mode command mean? I'm guessing to do a hi-volt wakeup you switch between normal (2) and wakeup (2) ? or maybe Sleep (0) and Wakeup (2)?
/me confused...
thanks!
