Results 1 to 1 of 1
Thread: Powering ELM327 Cable without a car?
    Newbie preet's Avatar
    Sep 2009
    Canada eh
    Heya,
    I have an ELM327 usb-serial cable. It powers up fine when I connect it in my car (ie I get a power LED turning on) and works as expected. I'm trying to do a bit of dev with it though, and I don't want to be sitting in my car for that [I don't need to query the ECU for anything... just ELM stuff like reset, set BR, etc].
    So I tried to power the cable outside of the car, but I can't seem to get this to work... the power LED doesn't even turn on. I applied 12VDC to the pin 16, and grounded pins 4,5. Does anyone have any advice?
    edit: this works fine if you know how to read a pinout and aren't an idiot
    Preet
    Check out my Frontend project!
    http://prismaticproject.weebly.com/blog.html
  1. elm327
    By howy121 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-02-2009, 10:18 AM
  2. BMW e90 and ELM327
    By cosmin_cosmin_1 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-17-2008, 08:42 AM
  3. Powering LCD with MacPac Cable...
    By twiggs462 in forum LCD/Display
    Last Post: 05-02-2007, 08:08 PM
  4. powering a usb cable
    By Nomader in forum General Hardware Discussion
    Last Post: 08-02-2006, 02:17 PM
  5. Questions about running cable, also powering questions
    By dudah85 in forum General Hardware Discussion
    Last Post: 05-31-2001, 09:36 AM
