Results 1 to 7 of 7
Thread: Peugeot / Citroen PID for VIN / Fuel level
    Dec 2011
    Hello guys,
    Im trying to find the VIN and fuel level on the bus of Peugeot / Citroen.
    I have seen a Lexia3 software reading both from the above vehicles, and apperantly without interrogation (at least none that i noticed) so the information is probably on the CAN bus, but i have recorded the bus (using my trusty NEO VI) and cant find the above data anywhere.
    Of course the above vehicles dont respond to standardized OBD interogation for VIN and fuel level.
    Can anyone advise on which PIDs can i find these ?
    thanks.
    Jan 2012
    VIN code and fuel level info,you can find it on your vehicle comfort CAN-BUS,
    do u have original RD4 on your vehicle ,if this true,so very simple,RD4 PORT A PIN13---CAN-L PIN10---CAN-H.
    sorry my poor english
    Dec 2011
    Quote Originally Posted by thinsy View Post
    What is RD4 ?
    On CAN-Bus, how can i read the VIN and fuel level ? with which command or where on the bus ?
    Oct 2008
    If the vehicles are too old to respond to EOBD/OBD2 then the query won't be on the Can-bus, but on the old-fashioned K-line.
    Dec 2011
    Quote Originally Posted by p2psmurf View Post
    i tried on a new C4 (2011) and can not get a reply to OBD2 interrogation, no fuel level and no VIN. so i thought they might either use a propriatery interrogation or perhaps have the above info on the bus somewhere ?
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    i have the same question. I drive a citroen xsara, and the only PID i can get from my car is engine RPM.. it is EOBD compliant and i know the lexia software can read everything.. but is it just a matter of finding the custom PIDs?
    Oct 2008
    No. The vehicle's engine ecu will not reply to any other questions using EOBD.
    I have the same "Problem" with a Saxo. Just RPM and the statement that it's EOBD compliant (which it is not).
    All other data and information can only be acquired with a scanner that uses the factory protocol.
  1. OBD-II -> Peugeot 207 fuel consumption measure
    By kolo2 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-20-2010, 05:55 PM
  2. Odometer and fuel level with OBD
    By adimaths in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-09-2009, 03:29 AM
  3. Fuel Level and Odometer
    By emersonvier in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-18-2009, 07:41 AM
  4. Fuel level, vatertemp etc, On an old car
    By gtv85 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-08-2007, 06:19 AM
  5. help setting up fuel level display using pcmscan
    By 3square in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-10-2007, 08:26 PM
