Results 1 to 6 of 6
Thread: OBD II Odometer command
    May 2011
    Question OBD II Odometer command
    Hi,
    I have an ELM327 based dongle.
    Using this dongle, I can get OBD data from my car.
    I successfully retrieved speed and RPM but I just can't get the odometer reading.
    Does anyone knows how to get the odometer reading from the OBD?
    I need the code to send to the ELM.
    Is the odometer command different between protocols?
    *I dont want any tools such as scantool etc.
    Thanks!!
    Oct 2008
    The odometer is not part of the OBD2 specifications. Therefor a generic command to read it does not exist.
    May 2011
    Thank's for your answer.
    Than what is the way to retrieve odometer reading from a car threw OBD connector?
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Only a few vehicles that I've seen support this, mainly more modern ones, but there is a way to fudge it.
    Mode $01 Pid $31. That will give you distance since MIL cleared. Since pretty much all vehicles have had their mil cleared at one point or another, you should be able to manually enter odometer, then just keep track of that number and add it to your base value.
    RevFE
    My Shop
    Oct 2008
    You can read the odometer with factory tools or equivalent (which support reading odometer values).
    May 2011
    Thanks!
    That's a great solution for my problem.
  1. Replies: 3
    Last Post: 11-07-2011, 04:24 AM
  2. Odometer with LCD
    By Gt12Eco in forum Newbie
    Last Post: 02-04-2010, 12:38 PM
  3. Odometer
    By ACCLR8N in forum FB Sensors
    Last Post: 11-09-2009, 10:13 PM
  4. MPG & Odometer
    By xbomb2 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-15-2007, 03:11 AM
  5. ODB-II Odometer
    By kiwiuser in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-24-2007, 03:34 AM
Tags for this Thread
