Results 1 to 4 of 4
Thread: How send the OBD Request Messages to my Vehicle so I can see it's Responses?
    Jan 2012
    Question How send the OBD Request Messages to my Vehicle so I can see it's Responses?
    I am having USB to OBDII converter (OBDPRO), which is having USB at one end and 9 pins at another end.
    I want to test the OBDII Command on my OBDII Compatible Vehicle.
    I am aware of OBDII commands defined by SAE J1979 along with it's modes.
    And using those commands I want to send the Request Messages to my Vehicle so I can see it's Responses.
    Please tell me the procedure to do so.
    What type of console I need to execute OBD II commands?
    Can I use OBD commands to do so or I need some other form of command to execute as I am having USB on my Laptop Side?
    Please help!!!
    Thanks in Advance!
    Mohan
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    First, what os are you using? I'm going to assume windows, though that makes it oonly slightly more difficult. You need to ddownload drivers for your Obdpro device. This will aallow it to show up as a virtual com port. Then you can take your favorite serial console such as putty , open the com port, usually at 38400 or so baud, then send whatever command you wish. 0100 010C and 010D are three that mmost any vehicle will support.
    RevFE
    My Shop
    Jan 2012
    Thanks a lot!
    let me try it...
    Nov 2003
    Connecticut
    i used to use putty.
  1. Mode 9. Request Vehicle Information for KWP 2000(ISO 14230)
    By proyectanteATE in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-22-2011, 08:38 AM
  2. GM Mode 2C and AA request/responses
    By Rezista in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-16-2010, 11:50 PM
  3. How to send messages to programs?
    By the_big_1 in forum Newbie
    Last Post: 06-26-2008, 01:52 PM
  4. Replies: 120
    Last Post: 04-08-2008, 12:04 AM
  5. Jott.com - Send Text Messages by Voice
    By ToddW65 in forum Off Topic
    Last Post: 01-18-2008, 02:04 PM
Tags for this Thread
