Results 1 to 4 of 4
Thread: Odometer Conversion
    Jan 2012
    Odometer Conversion
    I am in the process of exporting my Volkswagen Caddy 2007 overseas and need to change the mileage travelled from miles to kilometers, can anyone tell me what software and cable I would require to achieve this.
    Any help will be appreciated
    Oct 2008
    You would need VCDS from Ross-Tech to do this.
    The kit will also be able to read all systems in your car - fault codes and live data, etc.
    If you do not plan on using that you would be better off (cheaper) by having somebody do it for you.
    Jan 2012
    Thank-you for the info
    Do you perhaps know what the process would be once I have the VCDS to change from Miles to Kilometers?
    Thanks Again!
    Oct 2008
    I think coding in Instrument cluster. Set country to Europe.
    See: http://wiki.ross-tech.com/wiki/index...Caddy_%282K%29
  1. gps like an odometer
    By filjoa in forum GPS
    Last Post: 02-08-2010, 08:34 AM
  2. Odometer with LCD
    By Gt12Eco in forum Newbie
    Last Post: 02-04-2010, 01:38 PM
  3. Odometer
    By ACCLR8N in forum FB Sensors
    Last Post: 11-09-2009, 11:13 PM
  4. MPG & Odometer
    By xbomb2 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 08-15-2007, 04:11 AM
  5. ODB-II Odometer
    By kiwiuser in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-24-2007, 04:34 AM
