Results 1 to 4 of 4
Thread: OBDII from scratch.... No vehicle ECU
    Mar 2012
    Hi all,
    This is my first post and I am currently building a classic Mini from scratch and have had my eye on this forum for a long time. My plan is to build the mini such that from outside of the car, the classic nature is kept, however, once inside the car, it will be very digitalized. No gauges etc... Just screens and touchscreen buttons... I am yet to decide on hardware etc but I am thinking of running Centrafuse. I would like diagnostics etc but obviously the car has no sensors / ecu / OBD plug so my question is as follows:
    Is there something that explains how OBD is communicated? I can make an embedded board with my own sensors measuring all the data but I am just not sure how to program it such that it outputs OBD commands that would be recognisable by any OBD sensor and hence work with Centrafuse.
    Has anyone done anything like this before? I have tried searching but I don't really know what to search for so it hasn't turned up much
    Any help would be hugely appreciated!
    Thanks!
    Oct 2008
    To get any respons on the data you would need a can-bus.
    Are you a senior hardware engineer and a senior software engineer espicially with embedded software?
    When no, I would look into other possibilities.
    I would convert the engine to take an aftermarket ecu.
    I would use a Gems programmable after market ecu and a Gems programmable dashboard.
    Gives you multiple pages of data, but still has the old knobs, I am afraid.
    The disadvantage is that GEMS is difficult to map.
    Maybe Motec is an alternative. have a look here: http://www.motec.com/products/productoverview/
    FLAC SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I think fusion brain or phidgets would be your best bet since you could tap into the sensors that are on the car already you won't get much from the old mini motor but you could get coolant temp, oil pressure/temp, volts, amps, not sure on rpm as you would need to tap into a tachometer to get the signal. And both those boards have CF or RR support. just a thought SNO
    Mar 2012
    I'm not a senior engineer no but I do have experience with embedded systems and programming them. I was planning to install my own sensors around the car to measure anything I want (RPM, temps, volts etc etc). I would then build an interface based on a microcontroller. These sensors will be plugged into my microcontroller interface which will read all of the sensors.
    I figured OBDII is technically just a communication protocol so surely if I can program my microcontroller to output the data from the sensors in the same format as OBDII then any computer would just think it is receviing OBDII signals and read it just fine. I've got a microcontroller built up that reads sensors and sends the data via serial to a PC.
    I know the mini doesn't have many sensors but I will be installing my own.
    Any thoughts?
  1. OBDII software that shows Vehicle Calibration ID
    By searcherrr in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-18-2011, 08:19 AM
  2. J1708 and OBDII in same vehicle
    By Aberk in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-01-2010, 10:29 AM
  3. OBDII vehicle speed acquisition
    By S_Steve in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 07-28-2008, 01:06 PM
  4. Searching for OBDII confirmed vehicle list and standards
    By Michael2006 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-29-2006, 02:15 PM
  5. From Scratch
    By GazzaW in forum Newbie
    Last Post: 03-01-2005, 08:58 PM
