Yes, it is possible. You can design a device to do what you described, or use the built-in PowerSave functionality of STN1110.
http://www.scantool.net/downloads/79...-powersave.pdf
STN1110 can sleep/wake up on voltage level, and it can wake up on voltage change (which is the most sensitive/reliable way). It also lets you set custom timeouts (e.g., voltage<12.5V for 10 minutes).
You can request a free sample of STN1110 from obdsol.com.
Vitaliy
LinkBack URL
About LinkBacks
See the datasheet for a description of the IC:
